Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Some wires connected in schematic didn't get reflected in PCB in circuit studio when I updated my PCB document. Please help?
  • Locked Locked
  • Replies 8 replies
  • Subscribers 89 subscribers
  • Views 2973 views
vaidyaparth
vaidyaparth over 8 years ago
I created a schematic on circuit studio and when I transferred that design on the PCB, some connections of the schematic were missing in PCB. Also, there were no errors generated when I compiled my project. What might be the issue?
I am attaching screenshots  of  my schematic as well as my PCB document.
Take a look at pin no. 2,3,4,10,11,12 of PCB component T1 which is transformer that can be seen in the schematic.
Also take a look at LT3573 IC in pcb. Its pin no. 4 is connected to resistor R3 in the schematic but it is not connected to R3 in the PCB.
  • e14softwareuk
    0 e14softwareuk over 8 years ago
    From the PCB try running Tools | Netlist > Clear All Nets and then from the schematic updating the PCB using Home | Project > Update PCB Document. Also are all your schematics and PCBs up to date with any changes you may have made to library parts.
  • vaidyaparth
    0 vaidyaparth over 8 years ago in reply to e14softwareuk
    Sir,
    I tried your solution. It is still not reflected.
  • e14softwareuk
    0 e14softwareuk over 8 years ago in reply to vaidyaparth
    There may be some error in library components causing a mismatch. Can you send through the design to software@element14.com and I will be able to take a look for you.
  • vaidyaparth
    Failed to match components is the problem. How can I solve it?
  • e14softwareuk
    If there is a mismatch between schematic and PCB then from within the PCB editor use Tools | Component Links to ensure everything matches up.
  • vaidyaparth
    only schematic file?
  • vaidyaparth
    Yes, I went to component links and I selected add pairs matched by designator option and then performed update. But still the problem is not solved.
  • e14softwareuk
    Can you supply a copy of the project as requested? This should help us to identify what the issue is.
