Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum New feature is 1.5 - Can't export BOM's to Excel
  • Locked Locked
  • Replies 25 replies
  • Subscribers 90 subscribers
  • Views 6142 views
  • frontpage
Sparkylabs
Sparkylabs over 8 years ago
i can no longer export BOM's in excel format. If i use the template I used to use in xlsx format CS now cannot work with this. having converted my template to XLT excel cannot handle the output from CS. So new version and MORE bugs.
Where do I send my invoice for the time I am wasting on this software? some of us have businesses to run!
  • voltsandjolts
    voltsandjolts over 8 years ago in reply to Sparkylabs +1
    Look I didn't suggest you re-edit the BOM!
  • voltsandjolts
    0 voltsandjolts over 8 years ago
    XLSX BOM created through an XLT template works for me in 1.5.1
    Can you share your template?
  • Sparkylabs
    0 Sparkylabs over 8 years ago in reply to voltsandjolts
    It even refuses to work with a their own template, the BOM export is a mess. I have tried reinstalling but this has put me back to 1.41 and this too suffers from the problem. I have this now on two computers so it is not machine specific. What data CS attempts to put into an excel file is too corrupt for excel to use so basically altium need to pull their fingers out of their arses and produce a bug fix that will apply to 1.41 because I don't see why I should be paying a maintenance licence for the fixing of basic functionality.
    I will have to use csv format that cannot be directly used by excel as it converts wurth electronic electrolytic capacitor part numbers into floating point thus destroying the data. The only way around this is to start a new spreadsheet and import the csv data.
    Perhaps it's time microsoft buy out altium. while they generally ruin anything they buy I can't possibly see how you can make CS any worse - ok you could but really this is ridiculous. I have wasted 3 hours on this.
    I am not allowed to attach the file format for excel templates. The template was derived from one of theirs and has worked fine in the past.
  • voltsandjolts
    0 voltsandjolts over 8 years ago in reply to Sparkylabs
    Hmmm, may there is something in the project which is upsetting the export.
    "used by excel as it converts wurth electronic electrolytic capacitor part numbers into floating point thus destroying the data"
    Right click on those cells, select Format > "Text"
  • Sparkylabs
    It has happened on two different projects on two different computers. the only commonality is that the BOM is for a project variant.
    No I can't change the text format in excel. Even if I do as you suggest it retains the formatting in floating paint notation even though it would no longer be recognised as such the original part number is destroyed, it has to be "imported" in order to not try and be clever.
  • voltsandjolts
    All the CSV file fields should be in quotes by default so they don't get 'smartly' converted. For example:
    "FS1","FUSE LITTLEFUSE POLYFUSE 2200mA 30V THRU-HOLE","1","Farnell","1175-844","",""
    So, "1175-844" doesn't get converted to 331.
    Did you add extra quotes around the Wurth part numbers? Or maybe there is some escape char in the part number?
  • voltsandjolts
    0 voltsandjolts over 8 years ago in reply to voltsandjolts
    Also, I don't use variants so maybe there is an issue there, as you suggested.
  • Sparkylabs
    Look CS offer output in CSV it should format the file appropriately, I'm not going to re-edit the BOM everytime I export it. Basically the whole BOM export is buggy.
  • Sparkylabs
    Well I need variants in these projects as they are designed to have a common PCB with options.
  • e14softwareuk
    0 e14softwareuk over 8 years ago in reply to Sparkylabs
    If you are creating the BOM in CSV format then the trick is to read it into Excel correctly. Do not just open the file otherwise it does tend to mess up things that look like numbers or dates, it is a complete pain the way it messes up data. Use the import option instead - a good randomly found link on the subject if it helps https://www.hesa.ac.uk/support/user-guides/import-csv .
  • voltsandjolts
