Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Unknown pin error
  • Locked Locked
  • Replies 8 replies
  • Subscribers 89 subscribers
  • Views 13455 views
  • frontpage
Unknown pin error
Sparkylabs
Sparkylabs over 8 years ago
When I try to bring may schematic design into the PCB I find that a newly created capacitor gives an error. "unknown pin" well the pins are 1 and 2 in both the symbol and footprint and I have use both before so as always I am baffled.
I would attach the files but Element 14's own software file formats are not accepted and the attach functionality is scarcely functional.
  • e14softwareuk
    0 e14softwareuk over 8 years ago
    Can you confirm if the component was added - I think I have seen it where you get the pin errors because the component doesn't exist on the PCB and so the pins cannot be found.
  • Sparkylabs
    0 Sparkylabs over 8 years ago
    Ah, yes they are missing from the PCB but I assume that is due to the error? so how do I resolve the error by adding parts that do not want to be added because of the error.
  • e14softwareuk
    0 e14softwareuk over 8 years ago in reply to Sparkylabs
    It could be the schematic symbol somehow isn't referencing the footprint correctly (or footprint not found) and so it does not get added to the PCB.
  • Sparkylabs
    0 Sparkylabs over 8 years ago in reply to e14softwareuk
    Well even changing the footprint on the symbol on the schematic does not help. What is the correct procedure for getting the design from schematic to PCB and then updating ? all other parts are working fine.
  • e14softwareuk
    As a test try changing the footprint of the cap on the schematic document to any other 2 pin footprint you know works and then run Home | Project > Update PCB Document from the schematic. A second test would be to manually add the footprint to the PCB, make sure the cap on the schematic is using the correct footprint name and then try Update PCB Document again.
  • Sparkylabs
    Manually placing the capacitors on the PCB worked. on running the board update it wanted to remove them so I had to untick the boxes for that operation or I'd be back to square one. i can't carry an working like this though.
  • e14softwareuk
    If it worked manually placing them then it seems to suggest the software is having problems locating the footprint library as set in the symbol on the schematic. If you set the designator on the PCB of the manually added caps it should not want to remove them. Is the new cap footprint in the same library as you are using for other components that are working? If so check how you are referencing the new cap footprint compared with ones that are working.
  • Sparkylabs
    For some reason the symbol type was set to mechanical. I believe it is fixed now
