Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum CS problems
  • Locked Locked
  • Subscribers 91 subscribers
  • Views 855 views
  • frontpage
CS problems
photivs
photivs over 7 years ago
Hi
I'm new user of CS and have the following problems:
1. On PCB layout, when i draw a track, i want a hot key to change layer and to place automatically a VIA. Within CS i couldn't find a such key (or shortcut).
2. If i press accidentally the "Windows Start" key (which lies exactly next to the CTRL key which is used very often) the CS gets stuck in truck drawing. The only way to escape, is a forced termination of CS from Windows, and everything that has designed so far will be lost.
3. I have troubles with copper pour (polygon pour). I try to apply a GND plane on bottom layer, but except the GND net and all other bottom tracks are merged within the copper pour area.
Thanks for any help.
  • batuu
    0 batuu over 7 years ago
    To answer your first question:
    Here you cann find some interactive routing shortcuts:
    http://documentation.circuitstudio.com/display/CSTU/PCB_Cmd-Routing_Composite((Interactive+Routing))_CS
    If you press 2 you get a via in the current route. Pressing L switches the Layer.
  • voltsandjolts
    0 voltsandjolts over 7 years ago
    1)
    You can view some useful shortcuts like this under menu option View Tab > Shortcuts
    There is also online documentation such as this:
    Interactive Routing | Online Documentation for Altium Products
    In short, you can use the plus or minus keys or shift + ctrl + mouse wheel.
    2) What is truck drawing?
    3) Polygon pour options > Net Options > Pour over all same net objects
  • photivs
    0 photivs over 7 years ago in reply to batuu
    Thanks a lot.
    Yes, change layer + VIA can be obtained by pressing CTRL+SHIFT+Mouse Wheel. If you press 2 only VIA, to change layer you have to press L.
  • photivs
    0 photivs over 7 years ago in reply to voltsandjolts
    Track not truck.
    Truck is a vehicle.
    "Track Drawing" is a different expression of "Routing a Connection".
    BTW, in my old PCB software, by pressing only TAB, both at once: change layer + VIA.
    For multilayer PCBs with mouse Right Click, you can select any of the middle layers.
    Thanks a lot
  • photivs
    Hi
    Regarding my second question, i found the solution.
    When you route (or draw) a track with mouse, your left hand fingers are on the keyboard CTRL and SHIFT keys.
    Unfortunately, next to these two keys lies the "Windows Start" key.
    If you press accidentally the "Windows Start" during routing, the CS gets stuck in routing.
    If it happens, press the right mouse button to end the routing process, and another one time to exit from routing.
