Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum a better way to get emages of schematics out of CS?
  • Locked Locked
  • Replies 9 replies
  • Subscribers 90 subscribers
  • Views 1298 views
  • frontpage
Sparkylabs
Sparkylabs over 7 years ago
Currently if i want to have an image of a diagram I copy the diagram and poste ito an image editor. But I see that the resolution is poor and for example a box with border has 2 thick border lines and 2 thin ones or other combinations down to missing border lines. Is there a better way to do this?
  • voltsandjolts
    0 voltsandjolts over 7 years ago
    Hi Simon,
    For inserting schematics into documentation (MS Word) I use this process to get nice sharp vector graphics:
    Export schematic PDF from CS as usual.
    Run the vector graphics program 'Inkscape' (free, open source)
    Select File>Import and select the PDF schematic
    The schematic will be imported as one 'grouped' object. Select it then Object>Ungroup several times to separate all the pieces.
    Delete any bits you don't want, e.g. background colour, drawing frame etc.
    Resize the page to your drawing objects: File>Document Properties>Page>Resize page to content
    File>Save a Copy and select file format as EMF format
    In Word, insert Picture, select EMF file.
    It only takes a couple of minutes, if you have used Inkscape before.
    BTW I find GIMP and Inkscape to be excellent tools and just knowing the basics has been so useful...for labels, documentation diagrams, etc.
    Rgds,
  • Sparkylabs
    0 Sparkylabs over 7 years ago in reply to voltsandjolts
    Ah, that sounds like a plan. but how do you get a schematic to export in PDF? I have to use the microsoft windows 10 PDF printer because the export schematic bit of CS never works. It always only partially covers the page even though the PDF and schematic are A4. Attemps at getting it to scale were fruitless.
  • voltsandjolts
    0 voltsandjolts over 7 years ago in reply to Sparkylabs
    Project Toolbar > Generate Outputs > Schematic Prints (In Page Setup select Scale Mode : Fit Document)
    The PDF is saved in the "Default Configuration" folder (in the CS project folder)
    BTW: PDF page order is determined by the "SheetNumber" property of Document Options (on Project toolbar)
  • Sparkylabs
    Yea, I usually get a schematic A5 size on an A4 sheet.
  • Sparkylabs
    Oh and CS changes the fonts for the PDF and is all comes out with squished up text. CS export scematic is broken I am afraid. Another bug they will never fix but it's OK because we got 3D PDF.........NOT!
  • voltsandjolts
    Thats odd, I have never seen that, PDF has always been fine for me.
    I'll count myself lucky.
  • Sparkylabs
    Well for PDF's i can use the outputs tab and go to print and use the microsoft printer but it is annoying that CS has a sort of locked in syndrome. You can't get any information out of it in another format that another program can use.
  • Sparkylabs
    Unfortunately the microseft export to PDF just makes a picture of it
  • Sparkylabs
    0 Sparkylabs over 7 years ago in reply to Sparkylabs
    aha, i can change the font of text if once ungrouped back to what is was supossed to be.
