Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum changing layers while routing in circuit studio 1.5
  • Locked Locked
  • Subscribers 91 subscribers
  • Views 2698 views
  • frontpage
madcap
madcap over 6 years ago
Working in Circuit Studio 1.5. Perhaps I'm doing this wrong. When I start interactive routing on layer 1, I the hit the tab key and I get a popup window with options. There is a drop menu where I select layer 2. I would expect that would be the way to switch the routing trace between layers while routing (a via would automatically be created). When I return to routing, the tracks are still being routed on layer 1. No via. How do I change layers while routing?
Thanks in advance,
Greg
  • adamwebber
    0 adamwebber over 6 years ago
    While routing, hold CTRL + SHIFT and use the scroll wheel to cycle through your layers.  It will automatically place your default via size.  Takes some practice in order to feel comfortable doing it.
    To change your default via size, select via by pressing 'V' on your keyboard or select Via from the Home tab.  Now press TAB.  Change all of the settings of your via here.  It defaults to your new settings when you press 'OK'.
  • madcap
    0 madcap over 6 years ago in reply to adamwebber
    Thanks James,
    Your method works very well. Actually faster too. Crazy that the tab key/properties window method doesn't seem to work?
    Take care,
    Greg
  • IanJ
    0 IanJ over 6 years ago in reply to madcap
    For info.......on a 2-layer board just hit the asterix * button and it'll drop a via and switch layers at same time and you carry on routing (not sure what asterix will do on a 4-layer board for example though).
    Hit "2" or "v" are other options of dropping vias and carrying on.
    Ian.
