Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum How to generate a BOM for a single schematic within a project that contains multiple schematic sheets?
  • +1 person also asked this people also asked this
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 5883 views
  • bom
  • output
  • circuit studio
epenchansky
epenchansky over 4 years ago
Hi everyone!
I was wondering how to generate BOM for a single schematic within a project that contains multiple schematic sheets in CircuitStudio. Thus far, I have only been able to manage generating a BOM for the entire project. I recall being able to do this easily with Altium Designer, but there is some nuance to CS that I am missing. This Altium Academy video briefly covers BOM creation with CS. https://www.youtube.com/watch?v=-CaAJMwRq7I
The narrator mentions that there is an option under the Outputs tab for performing this type of operation, but they never show it being done in the video. When I click on the Outputs tab, this is all I see.
Is it actually possible to generate a BOM for a single schematic sheet that lives in a project containing multiple schematic sheets in CS? If so, what is the procedure?
  • jonasschmidt
    jonasschmidt over 4 years ago +1 verified
    Hi, I had the same question some time ago. There is a way to do this, see this post: /products/manufacturers/altium/f/forum/39663/outputs-bom-for-only-one-pcb-of-the-project It's also the way to go if…
  • epenchansky
    epenchansky over 4 years ago in reply to jonasschmidt +1
    Hi Jon, Thank you for sharing that. This technique worked perfectly for me on the first attempt. The knowledge will be put to good use!
  • cstanton
    0 cstanton over 4 years ago
    Moved to the Circuitstudio forums
  • tarribred61
    0 tarribred61 over 4 years ago
    I'm not aware if there is or isn't a direct way to do this.  The workaround should be to either temporarily remove the other sheets from the project and run the BOM or make a copy of the project and use the copy with only the sheet(s) you want.
    You might be able to do this using variants also but that would seem to be more difficult.
  • epenchansky
    0 epenchansky over 4 years ago in reply to tarribred61
    Thanks tarribred61. I will give that a try.
    What do you think the narrator is describing at 0:26 into the video? He mentions using the outputs tab.
  • tarribred61
    0 tarribred61 over 4 years ago in reply to epenchansky
    I'm not sure.  I don't think you can generate a BOM there.  You can print a single schematic page as a "non-smart" PDF, that is, it does not have the embedded information and parts parameters.  Mostly I use that tab for EDIF netlists, ERC and single pin net list checks.
  • jonasschmidt
    +1 jonasschmidt over 4 years ago
    It's also the way to go if you want to generate the schematic print of only one schem. (this might be important if you want to use the dynamic pdf function (all components clickable, show component information like parameters). This functionality was removed when I used a pdf editor to crop the output to just one page.
    TRANSLATE with x
    English
    Arabic Hebrew Polish
    Bulgarian Hindi Portuguese
    Catalan Hmong Daw Romanian
    Chinese Simplified Hungarian Russian
    Chinese Traditional Indonesian Slovak
    Czech Italian Slovenian
    Danish Japanese Spanish
    Dutch Klingon Swedish
    English Korean Thai
    Estonian Latvian Turkish
    Finnish Lithuanian Ukrainian
    French Malay Urdu
    German Maltese Vietnamese
    Greek Norwegian Welsh
    Haitian Creole Persian
    TRANSLATE with
    COPY THE URL BELOW
    Back
    EMBED THE SNIPPET BELOW IN YOUR SITE
    Enable collaborative features and customize widget: Bing Webmaster Portal
    Back
  • epenchansky
    0 epenchansky over 4 years ago in reply to jonasschmidt
    Hi Jon,
