ams OSRAM
  • ams OSRAM
ams OSRAM
Blog Reliable Products and Technology for Smoke Detectors
Join ams OSRAM to participate - click to join for free!
  • Author Author: CorinnaR.
  • Date Created: 30 Apr 2024 9:04 AM Date Created
  • Views 1028 views
CorinnaR.
CorinnaR.
30 Apr 2024
New optical technology for smoke alarms detect fire faster and more reliable – which helps to save lives and avoids false alarms binding precious resources at the wrong spot. The combination of a multi-spectral sensor and white LED emitter recognizes the unique spectral signatures of different types of smoke. The new technical concept to the design of next-generation smoke detectors has been developed and tested by ams OSRAM: We enable faster and more precise detection of hazardous situations caused by smoke or fire than other smoke detector on the market today. It also has the unique ability to distinguish between different types of fire and smoke, leading to more accurate alarms and less alarm artefacts due to, for example, dust. With the ams OSRAM technology, the emergency signal to first responders can now include information about whether the flame is from wood, plastic, oil, or some other material, so they can prepare the correct safety and extinguisher resources en route.
ams OSRAM has the most complete portfolio in the market for emitters, photo-detectors and integrated sensors covering physical (e.g. optical, efficiency etc.) and certification (e.g. UL etc.) solution requirements. Our broad multi-spectral sensor offering and technology know-how, combined with broad process ownership across all portfolio options, drives innovative next-generation detector solutions. ams OSRAM’s market-proven components with highest quality and reliability paired with long-term component availability, provide our customers with the reassurance of a single point-of-contact for on-demand customized design integration and assembly options beyond standard components.
For more information:
https://ams-osram.com/applications/industrial/home-building-automation
    DAB over 2 years ago
    Sounds like a good implementation. You can use the smoke absorption bands to get very early detection.
