KEYSIGHT TECHNOLOGIES
  • KEYSIGHT TECHNOLOGIES
Forum component testing with keysight dsox1102g scope
Join KEYSIGHT TECHNOLOGIES to participate - click to join for free!
  • Replies 40 replies
  • Answers 25 answers
  • Subscribers 22 subscribers
  • Views 7940 views
  • component tester
  • elenco
  • short
johnwater
johnwater over 6 years ago
hello would like to learn how to measure components on my elenco am radio kit.
am new to electronics, trying to figure things out.
read about lissajous patterns, just need some direction as to how to set up my connections, see if components are functioning as necessary.
my 9 volt battery gets hot, no audio output,so  i think i have short somewhere?
thanks
john
    Jan Cumps over 6 years ago in reply to johnwater +4 suggested
    The soldering is good. I see that most of the transistors are NPN. There's 2 PNPs that I can see (Q5, Q7). You have different part numbers for those? Electrolytic capacitors look correct (I can't see the…
    Jan Cumps over 6 years ago in reply to shabaz +4 suggested
    Looking at the potentiometer, it seems that it has been inserted from the wrong side (inserted from above instead of pushed in from the underside).. The movable switch part looks forced (blue), and the…
    Jan Cumps over 6 years ago in reply to fmilburn +4 suggested
    I think that the second pin of the switch is soldered to the wrong hole:
    0 Jan Cumps over 6 years ago
    ... also, does the documentation say when you should plece the wire J1?
  • fmilburn
    0 fmilburn over 6 years ago in reply to Jan Cumps
    Found a link to the instructions:  https://www.elenco.com/wp-content/uploads/2011/05/AM-550CK_REV-A.pdf
  • fmilburn
    It looks like J1 is supposed to be installed
    0 Jan Cumps over 6 years ago in reply to fmilburn
    ow, that’s excellent documentation. Respect to Elenco. A throve of practical knowledge ...
  • fmilburn
    I thought so too.  Really good.
  • johnwater
    0 johnwater over 6 years ago in reply to Jan Cumps
    the poles between the battery solders is infinity 0L.
    the other area circled was a screw up of mine where the copper shield came off.Called elenco and tech said to just solder longer leads to meet the other connections, which i did.these aeremitter of Q4 and+ of capacitor C12,and negative lead of C12 to resistor  R15.and they all show good continuity..
    i should have enclosed a parts list for you.
    thanks
    johnimage
  • johnwater
    0 johnwater over 6 years ago in reply to shabaz
    i took the knob off of pot so we can see underside better.the nut and washer fit on top side of board, there are 5 lugs to solder on bottom of pc board.
    looking at 3 of the lugs i will re-solder those to fill holes better,
    everything is soldered from the bottom ,not on top of board.
    how would i check to see if this pot is shorting out somewhere?
    johnimageimageimageimage
  • johnwater
    0 johnwater over 6 years ago in reply to fmilburn
    not seeing anything about a J1 in assembly, looks like they just leave it empty.
    john
    0 shabaz over 6 years ago in reply to johnwater
    Hi John,
    You can use your multimeter set to ohms to check any component that isn't in-circuit any more.
    1. Is the metal indicated to by the red arrow soldered or touching the body/shell metalwork? I don't understand why it isn't soldered to the adjacent rectangular slot in the PCB, basically. And also, if it is touching the shell, or soldered to it, that could be an issue.
    2. What's the resistance between the shell, and each of the three contacts for the variable resistor?
    3. And also, is the switch mechanism (blue arrow) touching the shell tab (green arrow)? If so, that could be an issue too, because it isn't supposed to be touching the shell tab. Again, this can be verified by the multimeter set to ohms and measuring from the switch contacts to the metal shell (do this for both of the switch contacts).
    An understanding of what this component is doing is needed; two of the contacts are intended to work as a switch, and the remainder three contacts serve as the potentiometer or variable resistor. The switch contacts should be electrically isolated (i.e. extremely high resistance, 0L on your meter) from the three potentiometer contacts _and_ the shell. If that's not the case, there is an issue.
  • fmilburn
    0 fmilburn over 6 years ago in reply to johnwater
    J1 is the jumper wire on page 8 of the instructions - it looks like you installed it
