Moto Mods
  • Moto Mods
Moto Mods
Forum 19P2 Clock issues
Join Moto Mods to participate - click to join for free!
  • Subscribers 58 subscribers
  • Views 849 views
  • mod
  • moto mod
19P2 Clock issues
rdecarre11
rdecarre11 over 9 years ago
I am trying to use the reference moto mod clock from 19P2, but looking at it on the scope, I cannot see anything.
I have some 30AWG wire running about 1" to my device, do you think that would cause clock issues?
Is there anything special about the clock driver I should know?
  • rdecarre11
    To answer the first question.. Yes. B1 is ON. image
  • dpwinkler
    dpwinkler over 9 years ago in reply to rdecarre11
    Hi Robert,
    The 19.2MHz clock requires the high speed bridge to be enabled, so try flashing your MDK with a project that enables it (like hdk/muc/display). Don't forget to flash the developer bootloader via MDK utility and changing the VID of the project to 0x42 first. Also, I set my A1 and A2 dip switches to "On, Off" to enable the high speed bridge and set B1 to on as you have already noted. Under this configuration, I was able to see the 19.2MHz clock on a scope.
    Hope this helps!
    David
  • rdecarre11
    rdecarre11 over 9 years ago in reply to dpwinkler
    Thanks for the help David!
    I'll check it out on the scope today. My A2 switch broke and basically floats back and forth. I hope I can get it to stay, otherwise I might try reference Moto Mod surgery.
  • motomodsdev
    motomodsdev over 9 years ago in reply to rdecarre11
    If you look at the schematic (page 19), you'll see the 19.2MHz is enabled by the High Speed bridge in the MDK (MHB_PWROFF_N).  If you aren't actually using the Bridge, you should be able to hold it in reset (MHB_RST_N) to prevent any potential interference.
  • rdecarre11
    So I never actually looked to see if the clock worked, I just got another oscillator because I needed 24MHz anyway.
    I think we can safely say that enabling the MHB and setting DIPs would get you the clock, for other people searching about this.
    Thanks for the help again!
