Weller
  • Weller
Weller
Forum I purchased a Weller reflow set
Join Weller to participate - click to join for free!
  • Replies 35 replies
  • Subscribers 10 subscribers
  • Views 7521 views
Jan Cumps
Jan Cumps over 3 years ago
The title says it all. I have a Weller solder station. They have IC reflow gizmos that work together with its hot air gun.
image source: sinuss.nl, the element14 retailer in Belgium and the Netherlands
These are little ovens, that you put on top of the IC you want to rework. Then you put the hot air pencil inside, to flow the solder.
There's a chip lifter (think: coal mine headframe) that can then lift the IC.
It can also be used to place ICs. Should help me with BGA designs.
It may be over-fancy. Paul Daniels and Louis Rossmann do all of this with just a heat gun. But I'm not that skilled - don't do it enough to be repeatedly successful.
My kit is also expensive. The one I bought, with support for 10x10 mm to 33x33 mm (with 6 steps in between), costs 500 €. An amount that I do not easily give away for tools.
Here's a video from Weller:
I have now burned my budget for the next two years (three years actually, but last year I didn't buy anything). It 'd better work as promised.
Send me your old PCBs, so that I can practice.
  • Andrew J
    Andrew J over 3 years ago in reply to scottiebabe +4
    Yes, so is the Metcal one of similar design. There's always a justification lurking somewhere though, you just aren't looking hard enough!
    Jan Cumps over 3 years ago +4
    Customer Action Video: https://youtu.be/-oNphHi_tUk The video is real time, raw footage. No comments or talk. End result: no pads ripped, no pins bent.
    Test 2, with a bigger IC and one of the bigger ovens. This was more eventful. Not because of the kit, but because of me, learning while on video. https://youtu.be/lWrsRHoDSZM The editing is very…
  • scottiebabe
    scottiebabe over 3 years ago
    May I ask what material is the vacuum lift head made of? Hot air temps are often blazing hot Fire...
  • Andrew J
    Yes, so is the Metcal one of similar design.  There's always a justification lurking somewhere though, you just aren't looking hard enough! Grinning
    shabaz over 3 years ago in reply to scottiebabe
    Those ceramic heating elements are low-cost (about $20, maybe a bit more now due to inflation)! There's a firm in Ireland called Ceramicx that makes very similar looking ones, I don't know if they are identical. Metal-work is hard though : ( Maybe there are other similar shaped products that could be hacked to produce that!
    I have a Thermaltronic pre-heater, which has quartz, it's pretty basic. The number on the temperature meter bears no resemblance to actual temperature on the board, and it has no external thermocouple probe connection. All I know, is that at max setting, it's barely adequate to melt leaded solder on it's own (anyway it's not intended to be used for reflow on its own, it's just a pre-heater). The Weller one is 200W, so that is just a pre-heater and not a reflow solution either (i.e.. it will also need hot air from top).
  • scottiebabe
    scottiebabe over 3 years ago in reply to Andrew J
    LOL this is true. Well if the Invertor of the QFN package wants to buy me a Christmas present, I might just learn to love QFNs! They make QFN soldering even easier :)
  • scottiebabe
    scottiebabe over 3 years ago in reply to shabaz
    Yes exactly! Mechanical things are not my specialty, so I don't think I'm up for a DIY solution lol I should shop around again and see if there are any ebay deals.
    Jan Cumps over 3 years ago in reply to shabaz
    I have this one:
    kindly donated by Arrow up
    Jan Cumps over 3 years ago in reply to scottiebabe
    some Teflon derivative. Heat resistant, yet flexible enough to create an air seal.
    The kit arrived. Preview:
    image image
    shabaz over 3 years ago in reply to Jan Cumps
    Nice! From the video it's literally a single-handed task too.. wasn't expecting it to be so straightforward!
