Würth Elektronik
  • Würth Elektronik
Würth Elektronik
Blog Charge time reduction
  • Author Author: zuberzahi
  • Date Created: 21 Aug 2021 3:28 PM Date Created
  • Views 1650 views
zuberzahi
zuberzahi
21 Aug 2021
Sir i am making a 60V battery pack with 3.2V and 10A small battery cell. And the battery takes lot of time to charge with 3.5 V charger that i am useing now, I reasearched to increase the charge speed I got to know Traditional 12V charger can be used to charge battery Can I use 12V charger to charge 3V battery, what might happen, is there any solution.
Thank you for your time please calrify
Can i change 3.5 V charger to which capacity charger
    DAB over 5 years ago +5
    I agree with Douglas. You do not want to fool around with charging any lithium based battery. Now I have seen some articles where people have built a cooling system for the batteries, which can allow them…
    dougw over 5 years ago +4
    12V would likely destroy a 3.2V battery. Optimal high speed charging requires controlling the current and adjustment based on battery temperature and voltage. It is difficult to optimize charging cells…
    Now I have seen some articles where people have built a cooling system for the batteries, which can allow them to be safely charged faster, but it requires very precise monitoring of the battery temperature.
    • Vote Up +5 Vote Down
    It is difficult to optimize charging cells in series, since each cell is different.
