Würth Elektronik
  • Würth Elektronik
Würth Elektronik
Blog DNS001: Enlighten your LEDs with this MagI3C Power Module
  • Author Author: sleuz
  • Date Created: 11 May 2015 3:36 PM Date Created
  • Views 1147 views
  • led;
  • shunt_resistor
  • high_power_led;
  • led_driver;
  • regulator;
  • operational_amplifier;
  • linear_regulator;
sleuz
sleuz
11 May 2015
REFERENCE DESIGN NOTE - imageLED Driver with MagI3C Power Module
DNS001: BY ROLAND KRATZ
MagI3C Power Modules
VDRM - LED Driver Application
7 - 24V INPUT / 0 – 1.5A LED CURRENT
1. Introduction
The DNS14 is a reference design for the WLMDU9456008T LED driver capable of driving up to 1.5 A output current using a voltage regulated module and an external secondary regulation loop to establish current regulation. The external loop regulates a DC output current which results in a constant photon flow. Compared to other solutions with PWM, this solution is less harmful to the eyes due to the constant photon flow, allowing the pupil opening to be the proper size for the light intensity emitted. Depending on the LED flux voltage up to 4 LEDs in series can be connected.
2. Features
Input voltage range from 7 V to 24 V
  • Output current up to 1.5 A
  • Adjustable current from 10 mA to 1.5 A
  • Dimming voltage 0 V (10 mA) to 5 V (1.5 A)
  • Current regulation
  • Output current ripple typ. < 10 mA
  • Output power up to 22.5 W
  • Series connected LEDs up to 15 V total flux voltage
Figure 1: Development Example
Figure 2: Simplified Schematic
3. Description
The power consumption of LEDs on the lighting market is constantly increasing. LEDs require currents of 700 mA, 1 A or higher. High output currents are supported commonly with voltage regulated modules. Constant high current led drivers are uncommon on the market. This design note describes how to convert a voltage regulated module to a current regulated module. Typical supplies for LEDs are modules operating as current sources. They include dual protection against output short circuits. A current regulated circuit is - if designed properly - short circuit protected by itself due to its nature of forcing a defined current into the load regardless if the load is an LED or a low resistance like a short circuit. The second overcurrent protection circuit is integrated in the module commonly through a cycle by cycle current limit.
A MagI3C VDRM module is used in this application. Natively it is voltage regulated. The current through a specific number of LEDs will flow from LED+ pin through the LEDs to the LED- pin. The LED current flows through a shunt resistor, R3, and the voltage across R3 is compared with a dimming voltage. A 5 V dimming voltage at the DIM terminal results in a voltage of 75 mV at the regulation loop amplifier (IC3, pin4) with which the shunt voltage (IC3, pin 3) is compared. IC3 is used for an outer and slower regulation circuit which drives the feedback pin of the VDRM module. The compensation network consists of C8, C9 and R6, which may be trimmed by the design engineer depending on the customer PCB layout if modified from the reference design PCB layout.
An external dimming (adjusting) voltage is always required. This can be derived directly from VIN if stable or from a resistor divider from the 3.3 V of the linear regulator (IC2). The supply of the operational amplifier is derived from VIN with a linear regulator (IC2) with a capability of abs. max. 40V or 60V input voltage. Its output voltage is set to 3.3V. The Input voltage of the design ranges from 7 V to 50 V (only with the 60 V version of the LM2936, which is not available in this small package) and the output current ranges from 0 A to 2.5 A. Note that the output power shall not exceed 22.5 W. The compensation may be adapted for various operating points.
This Reference Design is developed using the following specification:
Vin = 7 V - 24 V     Vout = 0 V - 15     V Iout = 10 mA - 1.5 A
4. Bill of Material
Index
Description
Size
Value
Order Code
Supplier
IC1
MagI3C power module
BQFN-41
WPMDU1251501N
171 021 501
Würth Elektronik eiSos
IC2
Linear regulator
SOT-223
LM2936(HV)
LM2936MP-3.3 (40V)
Texas Instruments
IC3
Operational amplifier
SOT-23
OPA364
OPA364
Texas Instruments
R5,R6,R8,R13
0603 1% TK100 125mW
1K00
R10,R11,R12
0603 1% TK100 125mW
2K00
R1
0603 5% TK100 125mW
10R0
R2
0603 5% TK100 125mW
0R02
R4,R9
Change R9 to your UVLO needs
0603 1% TK100 125mW
10K0
R7
Defines max current at 5 V at DIM pin/pad (5 V = 1.5 A)
0603 1% TK100 125mW
64K9
R3
Shunt resistor
1210 0,5% 250mW
0R05
C2,C3
X5R or X7R 1210 10%
10μ/50V
C5,C10,C11
X7R 0603 10%
100n/50V
885 012 206 095
C7,C9
COG,NP0 0603 10%
22p/50V
885 012 006 053
C8
X7R 0603 10%
22n/50V
885 012 206 091
C6
X5R 0805 20%
10μ/10V
885 012 107 010
Table 1: Bill of Material
5. Schematic and Layout
6. Suitable Würth Elektronik eiSos High power LEDs
WL-SWTC
SMD White Top View Ceramic LED
Size 3535, waterclear dome lens
CharacteristicsApplications
  • Fast switching
  • No IR radiation
  • High brightness
  • Minimal side emission
  • Waterclear silicone lens
  • Top view
  • Flexible coupling with secondary optic
  • Various color temperatures
  • Compact footprint
  • Thermal resistance junction to solder point: 8°C/W
  • LED junction temperature: 150°C
  • Interior lighting: Spot light, Down light, Shelf light
  • Outdoor lighting: Street light, Security light, Tunnel light, Parking lot light, Pedestrian light
  • Industrial lighting: High-bay light, Low-bay light
  • Consumer lighting: Torch light
  • White LEDs in agricultural equipment lighting
  • Signal and Symbol luminaries
Electrical & Optical Characteristics @ 0.35 A (typ.)
Order Code
Emitting Color
CCT
(K)
CRI
ΦV
(lm)
VF
(V)
Chip Technology
2θ50%
pdf
158353027
Sunrise
2700
80
95
3.2
InGaN
120
pdf
158353030
Warm White
3000
80
95
pdf
158353040
Moonlight
4000
75
110
pdf
158353050
Daylight
5000
70
121
pdf
158353060
Cool White
6000
70
121
CCT      = Correlated Color Temperature
CRI       = Color Rendering Index
ΦV       = Luminous Flux
VF        = Forward Voltage
2θ50% = Viewing Angle
Figure 5: Recommended High Power White LEDs
WL-SMDC
Ceramic mono-color High Power LED
imageCharacteristicsApplications
  • SMD ceramic package with high efficiency
  • Waterclear silicone lense
  • High brightness with minimal side emission
  • Viewing angle: 125°
  • Moisture Sensitivity Level: 2
  • Electrically neutral thermal path
  • Low thermal resistance: 8/10 K/W
  • LED junction temperature: 125°C/ 150°C
  • Architectural lighting indoor
  • Entertainment and stage lighting
  • Indoor smart lights
  • Horticultural lighting
  • Aquarium lighting
  • Traffic and signal lights
Order Code
Emitting Color
λPeak typ.
(nm)
λDom typ.
(nm)
ΦV
(lm)
VF typ.
(V)
Chip Technology
2θ50%
pdf
150353RS74500
Red
635
625
55
  1. 2.2
AlInGaP
125
pdf
150353YS74500
Yellow
593
590
50
  1. 2.2
AlInGaP
pdf
150353GS74500
Green
520
525
85
  1. 3.4
InGaN
pdf
150353BS74500
Blue
455
460
25
  1. 3.2
InGaN
λPeak   = Peak Wavelength
λDom   = Dominant Wavelength
ΦV       = Luminous Intensity
Figure 6: Recommended High Power Colored LEDs
IMPORTANT NOTICE
The Application Note is based on our knowledge and experience of typical requirements regarding these areas: It serves as general guidance and should not be construed as a commitment for the suitability for customer applications by Würth Elektronik eiSos GmbH & Co. KG. The information in the Application Note is subject to change without notice. This document and parts thereof must not be reproduced or copied without written permission, and contents thereof must not be imparted to a third party nor be used for any unauthorized purpose. Würth Elektronik eiSos GmbH & Co. KG and its subsidiaries and affiliates (WE) are not liable for application assistance of any kind. Customers may use WE’s assistance and product recommendations for their applications and design. The responsibility for the applicability and use of WE Products in a particular customer design is always solely within the authority of the customer. Due to this fact it is up to the customer to evaluate and investigate, where appropriate, and decide whether the device with the specific product characteristics described in the product specification is valid and suitable for the respective customer application or not. The technical specifications are stated in the current data sheet of the products. Therefore the customers shall use the
data sheets and are cautioned to verify that data sheets are current. The current data sheets can be downloaded at www.we-online.com. Customers shall strictly observe any product-specific notes, cautions and warnings. WE reserves the right to make corrections, modifications, enhancements, improvements, and other changes to its products and services. WE DOES NOT WARRANT OR REPRESENT THAT ANY LICENSE, EITHER EXPRESS OR IMPLIED, IS GRANTED UNDER ANY PATENT RIGHT, COPYRIGHT, MASK WORK RIGHT, OR OTHER INTELLECTUAL PROPERTY RIGHT RELATING TO ANY COMBINATION, MACHINE, OR PROCESS IN WHICH WE PRODUCTS OR SERVICES ARE USED. INFORMATION PUBLISHED BY WE REGARDING THIRD-PARTY PRODUCTS OR SERVICES DOES NOT CONSTITUTE A LICENSE FROM WE TO USE SUCH PRODUCTS OR SERVICES OR A WARRANTY OR ENDORSEMENT THEREOF.
WE products are not authorized for use in safety-critical applications, or where a failure of the product is reasonably expected to cause severe personal injury or death. Moreover, WE products are neither designed nor intended for use in areas such as military, aerospace, aviation, nuclear control, submarine, transportation (automotive control, train control, ship control), transportation signal, disaster prevention, medical, public information network etc. Customers shall inform WE about the intent of such usage before design-in stage. In certain customer applications requiring a very high level of safety and in which the malfunction or failure of an electronic component could endanger human life or health, customers must ensure that they have all necessary expertise in the safety and regulatory ramifications of their applications. Customers acknowledge and agree that they are solely responsible for all legal, regulatory and safety-related requirements concerning their products and any use of WE products in such safety-critical applications, notwithstanding any applicationsrelated information or support that may be provided by WE. CUSTOMERS SHALL INDEMNIFY WE AGAINST ANY DAMAGES ARISING OUT OF THE USE OF WE PRODUCTS IN SUCH SAFETY-CRITICAL APPLICATIONS.
USEFUL LINKS
Application Notes:
http://www.we-online.com/app-notes
Component Selector:
http://www.we-online.com/component-selector
Toolbox:
http://www.we-online.com/toolbox
Product Catalog:
http://katalog.we-online.de/en/
CONTACT INFORMATION
Max-Eyth-Str. 1, 74638 Waldenburg, Germany
Tel.: +49 (0) 7942 / 945 – 0
Email: appnotes@we-online.de
Web: http://www.we-online.com
