Würth Elektronik
  • Würth Elektronik
Würth Elektronik
Blog Exar Design Kit with four evaluation boards
  • Author Author: sleuz
  • Date Created: 14 Jan 2013 9:17 AM Date Created
  • Views 1502 views
  • exar
  • design_kit
  • step_down_converter
  • point_of_load
  • evaluation_board
sleuz
sleuz
14 Jan 2013
Design Kit from Exar
The design kit from Exar and Würth Elektronik provides single and dual-channel point of load solutions through a choice of four proven and ready to use fully integrated synchronous step-down converters. Four individual evaluation boards demonstrate various point of load's output current capabilities of 600mA to 1.5A per channel. System architects can further optimize their design with a variety of inductors from Wurth which is also included in the design kit. The selection of inductor offers various typical values and profiles, including the latest lowest profile options, to precisely tailor the power conversion stage for performance and ultra compact designs.
WE Order Code
IC-744721
Farnell Order Code
20827272082727
CharacteristicsApplications
  • Assortment of SMD Power Inductors
  • 6 sizes, 35 values, 825 components
  • Free refill
  • Suitable for switching power supplies of Exar
Evaluation Boards
SP6669XR6657XRP6658XRP6668
WE-HCI 7030
WE Order Code
L
(µH)
LR
(µH)
IR
(A)
Isat
(A)
RDC
(mΩ)
fres
(MHz)
Core Material
Size
Description
Farnell Order Code
PDF
744310013
0,13
0,11
22
48
0,91
400
Superflux
7030
WE-HCI SMD Flat Wire High Current Inductor
16361871636187
WE-HCI 7040
WE Order Code
L
(µH)
LR
(µH)
IR
(A)
Isat
(A)
RDC
(mΩ)
fres
(MHz)
Core Material
Size
Description
Farnell Order Code
PDF
744311068
0,68
0,52
17
20
3,1
105
Superflux
7040
16361901636190
PDF
744311150
1,5
1,12
11
14
6,6
72
Superflux
7040
16361911636191
PDF
744311220
2,2
1,75
9
13
11,4
52
Superflux
7040
16361921636192
WE-HCI 7050
WE Order Code
L
(µH)
LR
(µH)
IR
(A)
Isat
(A)
RDC
(mΩ)
fres
(MHz)
Core Material
Size
Description
Farnell Order Code
PDF
744314024
0,24
0,19
20
28
1
320
Superflux
7050
22116012211601
PDF
744314047
0,47
0,38
18
20
1,35
235
Superflux
7050
22116022211602
PDF
744314076
0,76
0,6
15,5
15
2,25
200
Superflux
7050
18906131890613
PDF
744314110
1,1
0,78
15
13
3,15
135
Superflux
7050
22116032211603
PDF
744314150
1,5
1,1
13
11
4,3
110
Superflux
7050
18906151890615
PDF
744314200
2
1,35
11,5
9
5,85
68
Superflux
7050
18906161890616
PDF
744314330
3,3
2,2
9
8
9
65
Superflux
7050
16361961636196
PDF
744314490
4,9
3,4
6,5
6,5
14,5
56
Superflux
7050
16361971636197
PDF
744314650
6,5
4,5
6
6
21,5
50
Superflux
7050
16361981636198
WE-HCI
1280
WE Order Code
L
(µH)
LR
(µH)
IR
(A)
Isat
(A)
RDC
(mΩ)
fres
(MHz)
Core Material
Size
Description
Farnell Order Code
PDF
74477010
10
6,2
6,6
0,019
0,022
18
Metal
1280
WE-PD SMD Shielded Power Inductor
16359251635925
PDF
744770115
15
5
6
0,024
0,027
14,5
Metal
1280
16359261635926
PDF
744770122
22
4,1
5
0,033
0,043
12
Metal
1280
16359271635927
PDF
744770133
33
3,2
3,6
0,047
0,064
8,5
Metal
1280
20825962082596
PDF
744770147
47
2,7
3
0,076
0,1
7,9
Metal
1280
16359281635928
PDF
744770168
68
2,3
2,5
0,09
0,14
6,4
Metal
1280
16359291635929
PDF
744770182
82
2,25
2,45
0,086
0,16
3,5
Metal
1280
20826002082600
WE-HCI
7345
WE Order Code
L
(µH)
LR
(µH)
IR
(A)
Isat
(A)
RDC
(mΩ)
fres
(MHz)
Core Material
Size
Description
Farnell Order Code
PDF
744777910
10
2
2,6
0,045
0,049
23
Plastic
7345
16359881635988
Find out more about Würth Elektronik here on element14
