Würth Elektronik
  • Würth Elektronik
Würth Elektronik
Blog Help Yourself
  • Author Author: sleuz
  • Date Created: 22 Nov 2012 6:54 AM Date Created
  • Views 1075 views
  • power_magnetics
  • application_guide
  • component_selector
  • design_tips
  • ic_reference_design
  • emc_search_engine
  • webench
  • lt_spice_simulator
Help Yourself
sleuz
sleuz
22 Nov 2012
Many different components and various demands in application and design making it hard for engineers and purchasers to find the best solution available.http://i.imgur.com/j3A3X.png
Würth Elektronik is offering free tools and softwares to get the perfect fit for you...feel free and help yourself!
Component Selector
The Würth Elektronik Component Selector is a design software to help you choose the right components.
It contains 4 modules:
  • Inductor Selector
  • FLEX Transformer Designer
  • RF Inductor Finder
  • Chip Bead Ferrite Selector
more...
http://www.we-online.de/web/media/07_electronic_components/panorama_1/Component-Selector_577_res01.jpg
http://www.we-online.com/solar/media/07_electronic_components/b_cher_brosch_ren_flyer/ltspice_Buch_res01.jpg
LTspice Simulator
This free simulation software helps you creating your layout piece by piece. Calculate and display timelines indcluding parametic variations.
LTspice IV is extensively used by IC designers and application engineers within LTC. It is used by engineers professionally, and is used by academics as well, in RF, power electronics, digital and other disciplines. LTspice IV does not natively support PCB layout, but netlists can be imported into various layout programs.
Würth Elektronik and Linear Technology offering a wide range of items to lay out your circuit.
more...
Application Guide
Würth Elektronik´s Application Guide is an easy-to-use brochure for Power Lines, Data Lines, Electromechanicals and RF Applications.
It is split in modules and applications so components and applications can be seen at a glance. Modules are subsystems which occur in several applications. Therefore modules are specified in detail on an extra page. The modules are marked yellow in all applications.
more...
http://www.we-online.de/web/media/07_passive_bauteile_-_standard/distributoren/ApplicationGuide_res10.jpg
http://www.we-online.de/web/media/07_passive_bauteile_-_standard/distributoren/8DesignTips_05_res10.jpg
8 Design Tips for Power Magnetics
A practical guide for the selection of power inductors for DC/DC converters.
more...
Webench Designer
Power Supply Design at Your Fingertips! - You can use WEBENCH to create customized power supplies or DC-DC converters for your circuits. This environment gives you end-to-end power supply designs and prototyping tools.
more...
http://www.we-online.de/web/media/07_passive_bauteile_-_standard/distributoren/IC_Hersteller_res11.jpg
IC Reference Designs
Find different IC-References online on www.we-online.de.
EMC Lab Search Engine
Get your nearby EMC Lab on www.we-online.de.
http://t1.gstatic.com/images?q=tbn:ANd9GcScwa8hMZN9ru8PEISmJG-iz81E2K2nzEhRSTKI4U7gj7oizErW
imageProduct & Application Overview Electromechanical Components.pdf
imageProduct & Application Overview Passive Components.pdf
