Würth Elektronik
  • Würth Elektronik
Würth Elektronik
Blog Long-range-WAN
  • Author Author: Würth Elektronik
  • Date Created: 14 Oct 2024 1:38 PM Date Created
  • Views 1190 views
  • product guide
  • radio modules
  • würth elektronik
  • wireless connectivity
  • knowledge
Long-range-WAN
Würth Elektronik
Würth Elektronik
14 Oct 2024
Long-range-WAN
Long-range-WAN
General information
Long-Range-WAN Architecture
A Long-Range-WAN-enabled end device is wirelessly connected to a long-range-WAN through radio gateways.
Uplink Transmission:
A Long-Range-WAN gateway receives messages from any end device and forwards these data messages to the Long-Range-WAN server (LNS). There is no fixed association between an end device and a specific gateway. Instead, multiple gateways can receive the same message from a single end device, the LNS performs data de-duplication and deletes all copies.
Downlink Transmission:
For downlinks communication, the Long-Range-WAN server (LNS) typically selects the gateway that received the message with the best RSSI when transmitting a downlink message. The gateway executes transmission requests coming from the LNS and forwards these data messages to end device.
Long-Range-WAN Deployment Options
There are different models for connecting end devices to a Long-Range-WAN network – private network, public network and hybrid network.
Comparison LowPowerWideAreaNetwork (LPWAN) Systems
Long-Range-WAN Classes
The Long-Range-WAN specification defines three device types: Class A, Class B, and Class C. In a long-range-WAN network, end devices operate in one of three modes: long-range-WAN Class A, Class B, and Class C.
Comparison Long-Range-WAN Classes
If you want to read more find here the whole Product Guide.
  • Würth Elektronik
    Würth Elektronik over 2 years ago in reply to JWx
    Thank you very much for letting us know. Please feel fee to deleate the comment if you want to. About your other question we wanted to say with that:
    If you want to send a command to a slave, you have to wait, until it sends data itself. No direct communication is then possible.
  • rsc
    rsc over 2 years ago
    Similar to the Amateur Radio "D-Star" network I use.
  • JWx
    JWx over 2 years ago in reply to JWx
    thanks for correcting - I don't know if I should now delete the above comment as outdated to not generate confusion? I have also doubts about class "A" - from my understanding, transmit-then-receive scheme should be very good (or at least acceptable) for remote control - we send command then listen for acknowledgement or some report Thinking. Maybe "devices" is the key - if "devices" means "remote control receivers" then it is ok - class A seems to be unsuitable for remote control receivers...
  • JWx
    This comment was deleted.
