Würth Elektronik
  • Würth Elektronik
Würth Elektronik
Blog RADIO MODULES: CERTIFICATION & CONFORMITY
  • Author Author: Würth Elektronik
  • Date Created: 15 Apr 2024 7:31 AM Date Created
  • Views 3011 views
  • conformity
  • radio modules
  • würth elektronik
  • certification
Würth Elektronik
Würth Elektronik
15 Apr 2024
Which Certification Rules apply where?
A product that is to be launched globally must meet the certification or conformity criteria of each country it is to be marketed in. There is no worldwide certification applicable to all countries. The following presents the various certification systems.
Different Certification Systems
image For products distributed in the European market the CE mark is required. The manufacturer applies the CE mark after fulfilling the Radio Equipment Directive (RED). The tests may be conducted either by the manufacturer himself or by an accredited laboratory. As self declaration the manufacturer is responsible for the products conformity to legal restrictions and regulations.
In North America, however, products with wireless technology require FCC certification. A certification through an verified authority with measurements is mantadory.
image For all other markets national regulations apply. For example, a product introduction in Canada or Japan require ISED or TELEC certification. Most countries are close to CE or FCC. Deadlines, requirements and measurements can differ.
image These, similar to other national regulations, are based on the existing certification bodies, so that only a small amount of additional testing is required. E.g. Canada or United Kingdom.
Certificate Examples
The manufacturer declares, that….                                                         The regulation body certifies that….
Benefits of Certification and Conformity
  • Be smart and ensure that your product will pass the certification process!
  • Obtain assurance – Precertification is half the battle won and reduces the final test effort.
  • Save time and money – the likelihood that the end product will pass is much greater with pre-certification.
All Würth Elektronik radio modules are either certified and / or declared for conformity. This simplifes the approval process of such a radio module within the end-application significantly.
If you want to read more find here the whole Product Guide.
  • Würth Elektronik
    Würth Elektronik over 2 years ago in reply to dougw
    This is correct, and falls into the category that we named national requirements. We did avoid a huge list, as it would go on with WPC for India, SRRC for China, Anatel for Brazil….
    Best regards,
    Würth Elektronik
    dougw over 2 years ago
    We also need to comply with KCC for products sold in Korea;
    genebren over 2 years ago in reply to DAB
    In High School we had a student run FM broadcast radio station.  Initially we all had to pass the Third Class FCC license test, but later some of us studied for and passed the Second Class FCC license test.
    DAB over 4 years ago
    Back in my Tech School days, we had the goal to get a Second Class FCC license, which would enable you to work on radio systems.
    If you were really good, you could get a First Class FCC license.
    I studied very hard and after a grueling 3 hour test, I came away with the Second Class, which was an automatic A for the class at school.
    At the time less then 50% of the people who took the test passed and only about 5% got the first class.
