Würth Elektronik
  • Würth Elektronik
Würth Elektronik
Blog Why using a radio module?
  • Author Author: Würth Elektronik
  • Date Created: 8 Jun 2022 11:33 AM Date Created
  • Views 841 views
  • radio modules
  • würth elektronik
  • wireless connectivity
  • communication
Würth Elektronik
Würth Elektronik
8 Jun 2022
Hardware
  • Powerful RF-Chips
  • Design of Ready-to-use Modules
  • Antenna-Design
  • Edge Castellation allows hand soldering in prototyping or small series production
Firmware
  • WE-ProWare Radio Stack
  • Requirement for approval (CE, FCC, IC, TELEC)
  • 20 years of experience
  • Developed for industrial and medical requirements
  • Easy to handle and to integrate
Software
  • Plug & Play PC-Software for easy evaluation, testing and updating
  • Mobile Apps for easy evaluation & testing
  • Design libraries available for fast PCB design for Altium and Eagle
  • Software Development Kit (C-Files) for comfortable coding of the HOST-controller system
ADDED VALUES
In comparison there is big potential for saving time and money by using an RF-module instead of the single RF-IC. With a pure HW-RF-module you can save HW-development resources, since the required circuitry is completely included. An integrated antenna enables an easy integration, even with a minimum of RF knowledge.
The software integration, testing and certification effort will be minimized if the Firmware is already available, because the FW is linked to module certification.
  • FASTEN TIME TO MARKET √
  • LOWER DEVELOPMENT COST √
  • INCREASE MARKET SUCCESS √
WHY “BUILD-YOUR-OWN-DEVICE“ IS 2ND BEST CHOICE
The situation for every system designer, purchaser or similar related functions is always the same. It needs to be compared between an “Off-the-shelf” solution or a “Build-Your-Own-Device” solution. For this process we want to offer a list of key aspects, which Wurth Elektronik sees as important to be able to take this decision.
We differentiate between three main categories in costs.
If you want to read more find here the whole Product Guide.
