PCB Design, Prototyping and Production
PCB Blogs KiCAD 8: RX23E-B kit - serial comms schematic
Join PCB Design, Prototyping and Production to participate - click to join for free!
  • Date Created: 2 Nov 2024 10:22 AM Date Created
  • Views 2236 views
  • Likes 8 likes
  • Comments 8 comments
  • kicad
  • rx23E-B
  • renesas
2 Nov 2024
I'm building a PCB for Renesas' RX23E-B microcontroller. In this post: the UART / serial communications design
I've taken over the design of the Renesas Solution Starter Kit for RX23E-B, without the FTDI serial-to-USB.
I'm not sure yet if I will keep the same uart peripheral. It shares its pins with the lcd segment outputs. And I may want to use those too. But if I change the uart, I can't reuse the Renesas out-of-box software ...
    shabaz over 2 years ago in reply to Jan Cumps
    Very interesting! I'd not seen this Bus Alias Definitions before!
    Jan Cumps over 2 years ago in reply to Jan Cumps
    done:
    progress:
    the crossed out resistors are flagged as Do Not Populate
    The net labels suppress an error for: same pin connected to multiple nets.
    I still get a warning, because the bus label shouts over the net label, ...
    Jan Cumps over 2 years ago in reply to shabaz
    I started the exercise. Meanwhile, learning the BUS functionality in KiCAD. It changed from a "dumb line" in KiCAD 4 and lower, to a structural concept.
    Bus definition:
    One idea could be to stick a flat-flex connector footprint on the board, so that the problem is pushed away to another day : )
    That's what Renesas did.
    Maybe I do the same, with the same footprint ...
    Part of the RX23E-B starter kit is a patch bay, where you can select the intended function with 0R resistors
