Raspberry Pi
Raspberry Pi
Blog 16X2 LCD Interfacing With Raspberry Pi
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: vinayyn
  • Date Created: 9 Oct 2022 7:29 PM Date Created
  • Views 10019 views
  • Likes 11 likes
  • rpibeginner
  • circuitpython
  • adafruit CharLCD
  • 16x2 lcd with raspberry pi
  • raspberry_pi
vinayyn
vinayyn
9 Oct 2022
I was searching for the 16x2 LCD Interfacing with Raspberry Pi and found that there are not many Instructions About interfacing the simple Connection anywhere in the Community Blogs Hence, I decided to create a small instruction to interface the LCD with Raspberry Pi using Adafruit CharLCD Library.
image image
To interface the LCD with Raspberry Pi we need to install The Circuit Python and CharLCD Library.
  1. Firstly, you need to install the circuit python Libraries. The following Link shows How to Install Circuit Python On the raspberry pi platform https://learn.adafruit.com/circuitpython-on-raspberrypi-linux/installing-circuitpython-on-raspberry-pi
  1. Then You need to install CharLCD Libraries by following the link.  https://learn.adafruit.com/character-lcds/python-circuitpython
Raspberry Pi to 16X2 LCD Pin Connections
Raspberry Pi Pins LCD Pins
GPIO26 RS
GPIO19 EN
GPIO25 D4
GPIO24 D5
GPIO 22 D6
GPIO27 D7
Circuit Connection Diagram
Simple Example code To display a message On LCD With Cursors Position Pointer
import time
import board
import digitalio
import adafruit_character_lcd.character_lcd as characterlcd
# Modify this if you have a different sized character LCD
lcd_columns = 16
lcd_rows = 2
# Raspberry Pi Pin Config:
lcd_rs = digitalio.DigitalInOut(board.D26)
lcd_en = digitalio.DigitalInOut(board.D19)
lcd_d7 = digitalio.DigitalInOut(board.D27)
lcd_d6 = digitalio.DigitalInOut(board.D22)
lcd_d5 = digitalio.DigitalInOut(board.D24)
lcd_d4 = digitalio.DigitalInOut(board.D25)
lcd_backlight = digitalio.DigitalInOut(board.D4)
# Initialise the lcd class
lcd = characterlcd.Character_LCD_Mono(
    lcd_rs, lcd_en, lcd_d4, lcd_d5, lcd_d6, lcd_d7, lcd_columns, lcd_rows, lcd_backlight
lcd.cursor_position(0, 0)# coloumn,row
lcd.message = "HI,"
lcd.cursor_position(3, 0)# coloumn,row
lcd.message = "Hope you are"
lcd.cursor_position(0, 1)
lcd.message = "Seeing The Video"
time.sleep(5)
lcd.clear()
lcd.message = "Raspberry Pi "
lcd.cursor_position(0, 1)# coloumn,row
lcd.message = "LCD Interfacing"
time.sleep(5)
lcd.clear()
Raspberry Pi 16x2 LCD Interfacing Result Video
  • vinayyn
    vinayyn over 3 years ago in reply to dougw
    yes it works i have interfaced the 20x4 also
    dougw over 3 years ago
    I have a 20 char x 4 line display. I think it would work with an identical connection.
    DAB over 3 years ago
    Nice simple project to get a good output device.
  • colporteur
    colporteur over 3 years ago
    Great share!
