Raspberry Pi
Raspberry Pi
Blog C++ write your own stream class - part 2: a working Pico UART IO stream (embedded friendly C++)
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Date Created: 15 Nov 2025 4:45 PM Date Created
  • Views 912 views
  • Comments 7 comments
  • Modern C++
  • pico
  • pico_eurocard
  • c++
15 Nov 2025
In C++ it's common to stream data. You write to a file using the << operator. You read with >>.
example:
cout << "hello, world! << endl;
In this blog I'm making my own minimal in, out and in-out stream class for Pico UART.
I put embedded friendly in the title because this is a resource-friendly exercise. Can be used on the smallest controllers.
How would your code look like?
You 'd stream data to UART with <<
uartiostream u;
    u << "hello element14!\n" ;
and stream from UART with >>
    std::string s;
    u >> s;
An example that first streams a constant string. Then echos everything you type in a serial monitor:
#include <string>
int main() {
    // ... usual Pico UART enable
    // c++ stream example
    uartiostream u;
    while (true) {
        std::string s;
        u >> s;
        u << s;
Pico UART Stream classes: in, out and io
The code for the stream classes is surprisingly simple.
class uartostream {
public:
    uartostream() {}
    uartostream& operator << (const char* msg) {
        uart_puts(UART_ID, msg);
        return *this;
    uartostream& operator << (const std::string& msg) {
        uart_puts(UART_ID, msg.c_str());
        return *this;
class uartistream {
public:
    uartistream() {}
    uartistream& operator >> (std::string& msg) { // blocking
        char c  = 0;
        do {
            c = uart_getc(UART_ID);
            if (c != 255) {
                msg += c;
        } while (c != '\n');
        return *this;
class uartiostream: public uartistream, public uartostream {
These classes are small in code size. And small in runtime resource use. Using them is similar for the Pico as calling the API uart_puts() and uart_getc() functions.
In essence: 30 lines of source code to get the streaming abstraction. And no runtime (memory, clock ticks, code size) overhead.
Example, with a few of the use cases mentioned above:
note: for the filter part, you have to add this to your cmake file:
set(CMAKE_CXX_STANDARD 26)
#include "hardware/gpio.h"
#include "hardware/uart.h"
#include <algorithm>
#include <array>
#include <ranges>
#include <string>
// UART defines
#define UART_ID uart0
#define BAUD_RATE 115200
#define UART_TX_PIN 0
#define UART_RX_PIN 1
class uartostream {
public:
    uartostream(uart_inst_t *uart) : uart(uart) {}
        // write to UART
        uart_puts(uart, msg);
        return *this;
        uart_puts(uart, msg.c_str());
        return *this;
private:
    uart_inst_t * uart;
class uartistream {
public:
    uartistream(uart_inst_t *uart) : uart(uart) {}
        char c  = 0;
        // msg.clear(); no. If the string has info, add to it.
        do {
            c = uart_getc(uart);
            if (c != 255) {
                msg += c;
        return *this;
private:
    uart_inst_t * uart;
public:
    uartiostream(uart_inst_t *uart) : uartistream(uart), uartostream(uart) {}
class dog {
public:
    dog (const std::string& name) : name(name) {};
    operator std::string() const {
        return "dog: " + name;
private:
    const std::string name;
class cat {
public:
    cat (const std::string& name) : name(name) {};
        return "cat: " + name;
private:
struct customer {
    customer (const std::string& name, int credit) : name(name), credit(credit) {}
    int credit;
        return name;
uart_inst_t * pico_init_uart() {
    uart_init(UART_ID, BAUD_RATE);
    gpio_set_function(UART_TX_PIN, UART_FUNCSEL_NUM(UART_ID, UART_TX_PIN));
    gpio_set_function(UART_RX_PIN, UART_FUNCSEL_NUM(UART_ID, UART_RX_PIN));
    return UART_ID;
int main() {
    uartiostream u(pico_init_uart());
    dog d("odie");
    cat c("garfield");
    u << d << "\n" << c << "\n" ;
    std::array<customer, 3> customers {{{"joe", 3}, {"jane", 500}, {"averall", -8}}};
    u << "insolvent customers:" << "\n";
    for(const auto &c : customers | std::views::filter([](const auto& c){ return c.credit < 0;})) {
                u << c << "\n";
    u << "rich customers:" << "\n";
    for(const auto &c : customers | std::views::filter([](const auto& c){ return c.credit > 100;})) {
                u << c << "\n";
    u << "full customer portfolio:" << "\n";
    std::for_each(customers.begin(), customers.end(),[&u](const auto& c) {
        u << c << "\n";
    while (true) {
        std::string s;
        u >> s;
        u << s;
Thoughts?
library repository
example code repository
demo VSCode project: uart_stream_20251116.zip
related post
    Jan Cumps 10 months ago
    what about his?:
    • Customer record:
    struct customer {
        int credit;
            return name;
    • Customer database:
    • Stream insolvent customers to uart:
        for(const auto &c : customers | std::views::filter([](const customer& c){ return c.credit < 0;})) {
                    u << c << "\n";
    • Output:
    and wealthy customers-:
        for(const auto &c : customers | std::views::filter([](const customer& c){ return c.credit > 100;})) {
                    u << c << "\n";
    Output:
    You could get code like this Slight smile
        dog d("odie");
        cat c("garfield");
