Raspberry Pi
Raspberry Pi
Blog Controlling a servo motor with the Raspberry Pi
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: fustini
  • Date Created: 8 Feb 2013 1:12 AM Date Created
  • Views 2008 views
  • rpibeginner
  • pwm
  • motors
  • raspberry_pi
  • servo
  • rpi
  • adafruit
fustini
fustini
8 Feb 2013
imageWant to build this project?
View Parts
During the last embedded systems meetup at my hackerspace in Chicago, The specified item was not found., we did hands-on activity where we went through a couple of Adafruit's wonderful tutorials.  First, we learned how to read a photoresistor without an ADC using Adafruit's Basic Resistor Sensor Reading on Raspberry Pi.  Next, we hooked up typical 5V hobby servo motor to the Pi per Adafruit's Raspberry Pi Lesson 8. Using a Servo Motor (written by element14 member simon.monk!):
The red board atop the Pi is the Pi Crust breakout board by Pumping Station: One member, Joe Walnes.  It's a compact and low-profile way to interface with the GPIO header.  Alternatively, the Pi Cobbler breakout board is shown in the Adafruit tutorial.  Note: the current Raspbian image doesn't have the Adafruit's PWM kernel module, so it is necessary to run Adafruit's Occidentalis image for the servo tutorial to work.
Fellow hackerspace member, Jay Hopkins, had the great idea to wheel over the oscilloscope to demonstrate how the pulse width of the signal on the Pi's PWM pin corresponds to the degree to which the servo rotates:
(The spining red board on top of the servo motor is just a spare Pi Crust.  It's only function was to make it easier to see the servo was moving.)
The Adafruit servo tutorial has a great explanation of how the position of a servo motor is controlled:
The position of the servo motor is set by the length of a pulse. The servo expects to receive a pulse roughly every 20 milliseconds. If that pulse is high for 1 millisecond, then the servo angle will be zero, if it is 1.5 milliseconds, then it will be at its centre position and if it is 2 milliseconds it will be at 180 degrees.
http://learn.adafruit.com/system/assets/assets/000/003/496/medium640/servos.png?1357725423
(source: Adafruit)
Here's a short clip showing the signal on the scope while the servo rotates:
Here's a longer clip where I explain the setup in further depth:
Cheers,
Drew
http://twitter.com/pdp7
Product Name*DescriptionSupplier
Raspberry Pi Model B Raspberry Pi model BRaspberry Pi
Buy Now
Optical mouse Basic USB optical mouseIONE / Pro Signal
Buy Now
Raspberry Pi power supply 120-240v to 5V power supply with micro USB connectorRaspberry Pi
Buy Now
Keyboard Basic USB keyboardGear Head / A4 Tech
Buy Now
Pre-programmed 4GB SD card 4GB Class 4 SD card preloaded with Debian 6 LinuxSamsung
Buy Now
Adafruit Pi Cobbler GPIO breakout kit for Raspberry PiAdafruit
Buy Now
Breadboard Basic breadboard with 830 connection pointsTwin Industries
Buy Now
Jumper wire bundle Jumper wires for use on breadboardBud Industries
Buy Now
5V Servo Motor Basic hobby servo motor, 5VAdafruit
Buy Now
*Products and resources listed are listed to help members build their own Pi Projects. They are suggestions and listed for educational purposes. For substitutions of any parts, please post a question asking the original author.
