Raspberry Pi
Raspberry Pi
Blog How to Set-up a Static (Fixed) IP Address on Raspberry Pi 2 and 3
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Date Created: 2 Apr 2015 5:50 PM Date Created
  • Views 2179 views
  • pi
  • rpi3
  • rpi2
  • raspberry-pi
  • networking
  • raspbian
  • feature_tutorial
  • linux
e14 Contributor
e14 Contributor
2 Apr 2015
This is a much-needed update to the blog entry that I wrote in April 2015 with respect to RPi2 and was last updated this past September.  Much thanks for comments by clem57 , anthonyworth , and sergiokob (RPi3 comments).
Why a static IP address for the Pi?  Well, you might not want it to change so that you can use a Pi in the following example repeated situations:
  • sshd (allow ssh clients to connect for various reasons)
  • rsync (copy from/to over SSH)
  • remmina (remote desktop server)
  • Samba (Windows file server emulation)
  • FTP
Keep in mind that a router would vary non-static dynamic address periodically during an automatic address renewal or after a Pi reboot (which usually causes a DHCP renewal).  So fixing the address of a set of common services is desirable.
Some administrative specifics about my LAN (router environment) to explain the addresses which appear later:
  • Router and DNS (combined in my router): 192.168.1.1
  • Dynamic address range: 192.168.1.{201, ..., 299}
  • Static (manual-assignment) address range: 192.168.1.{101, ..., 199}
The /etc/hosts file on one of my machines (biostar) contains the following static-address entries:
127.0.0.1    localhost
127.0.1.1    biostar
192.168.1.1     router
192.168.1.101    zotac
192.168.1.102    biostar
192.168.1.103    raspbian
192.168.1.104    pine64
The RPi2 file /etc/network/interfaces as installed today:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
So, it is not surprising that my Pi, according to `ifconfig`, was running eth0 at "inet addr" 192.168.1.235.
For the long-term, I want to fix my RPi2 using wired-Ethernet at 192.168.1.103.
For a WiFi test (EDUP USB/WiFi adapter), I will create a temporary WiFi static connection at 192.168.1.199.
It's most unfortunate that Raspbian-Jessie still does not include one of the network-manager GUIs found in many of the other LightDM-based distributions; this would have made this job simpler and not required manually editing of system configuration file(s).  On the other hand, this is an educational opportunity.
Keep in mind that the below-defined recipe may not work in future Raspbian releases.  For example, when I upgraded the "biostar" desktop Xubuntu image during 2015, I noticed that the network configuration strategy switched when migrating from the Ubuntu "upstart" service manager to the "systemd" service manager.  Surprise, surprise.  I had already gone through this once before from "SysV" to "upstart".  This is why Network Manage GUIs are so helpful and time-conserving.
Back to the task at hand - I followed this recipe today after a re-installation on my RPi2:
  • I left /etc/network/interfaces alone (Thank you, Sergio).  The 2015 strategy (SysV-oriented) of editing /etc/network/interfaces directly failed to work again in 2016.
  • I appended /etc/dhcpcd.conf with the following static information without the parenthetical comments:
interface eth0 (Wired-ethernet)
ipv4only (only using IPv4)
static ip_address=192.168.1.103 (following my /etc/hosts plan)
static routers=192.168.1.1 (my gateway address)
static domain_name_servers=192.168.1.1 (my router provides my DNS service which is fast enough for me)
interface wlan0 (WiFi)
ipv4only
static ip_address=192.168.1.199
  • I appended /etc/wpa_supplicant/wpa_supplicant.conf with the following static information without the parenthetical comments:
network={
               ssid="It's-a-secret"
               psk="It's-a-secret"
  • Reboot
Sergio (mentioned above) put his wlan0 static IP address in the /etc/wpa_supplicant/wpa_supplicant.conf file.  It can, apparently, go in either file.  I'll guess that he did this because he only wanted to modify one file since he had no wired-Ethernet connection to configure.
NOTE that if you create two connections to the same host, ssh client will not be happy with trying to switch from one to another - "Host key verification failed".  Work-around for me:
ssh-keygen -f "/home/elkins/.ssh/known_hosts" -R 192.168.1.103
Start over (`ssh 192.168.1.103`)
Since this recipe worked on RPi2 and RPi3 before, I assumed that the RPi3 would still work with the above recipe (I don't have one to test with).  Any RPi3 assistance will be appreciated.  I will correct as necessary.
