Raspberry Pi
Raspberry Pi
Blog Installing PyCharm on Raspberry Pi 4  (Updated: 02-27-2021)
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: gam3t3ch
  • Date Created: 12 Sep 2019 5:14 AM Date Created
  • Views 30035 views
  • Comments 24 comments
  • pycharm
  • python
  • raspberrypi
gam3t3ch
gam3t3ch
12 Sep 2019
Once you play around with all the IDE's available for python on Raspberry Pi you tend to want to play with PyCharm since well its probably what you have installed on your desktop or laptop.  Good news get it up and running on the pi in no time.   This is one of my favorite ones but tend to use MU IDE on smaller projects.
When it come's to the Raspberry Pi, even old issues come up and new fixes come to light.  Today I was playing around and found a new fix for our PyCharm issues.  I have had ton's of feedback on youtube about some of the more common issues that come up so lets get all of those sorted and get everyone up and running.  Let's check out the new method below and lets get programming!
----------------------------NEW METHOD--------------------------------
You can follow along on the video below.  This is the updated fix as of February 27, 2021
This video also shows how to setup the shortcut in your programming menu on the pi which sometimes doesn't like to populate.
You can download PyCharm community edition from: https://www.jetbrains.com/pycharm/download/#section=linux
And read about Martin's fix and download the files from here: http://youtrack.jetbrains.com/issue/IDEA-237956
I will also have the file below and will remove the file if Martin requests.
I am keeping the old fix below as it may still be useful for some users I will also updated any new things I come across that might help further.
-----------------------------OLD METHOD--------------------------------
Go to https://www.jetbrains.com/pycharm/download/
download the linux community version
in the downloads folder on your pi extract the files by right clicking on it and choosing extract here
open terminal  press ctrl+alt+t
Type: cd Downloads    then press enter
Type: ls       then press enter
you should see pycharm-community-2019.2.2
or something similar to that.
Type: sudo mv pycharm-community-2019.2.2 /opt/pycharm-community-2019.2.2    then press enter
Type: cd  then press enter
Type: cd /opt/pycharm-community-2019.2.2/bin   then press enter
Type: ./pycharm.sh then press enter
*if for some reason you are getting a Java error on the command run this sudo apt-get install openjdk-11-jdk
Then run the setup,  defaults usually work but read through and adjust to your liking
once welcome to pycharm shows up in the bottom you will see a configure cog click on that then select create desktop entry.
Select for all users you will have to enter your pi password for this part you will be prompted.
Create new project and then set your name for it and run.
It might take a few minutes for the program to load for the first time.
You will see the status in the bottom of the program running.
If you don’t have an icon on your desktop it is probably in the programming section in the raspberry icon then you can right click and add it to your desktop if you choose.
Fix For Terminal not working.
A big thank you to https://github.com/tuomastik  for the terminal fix you can use the code below or check it out on github.
https://github.com/jetbrains/pty4j/issues/82
open terminal (Ctrl+Alt+T on the keyboard)
git clone https://github.com/JetBrains/pty4j.git
cd pty4j/native
gcc -fPIC -c *.c
gcc -shared -o libpty.so *.o
cp libpty.so /opt/pycharm/lib/pty4j-native/linux/x86/
That’s it start playing with python!
https://community.element14.com/cfs-file/__key/communityserver-blogs-components-weblogfiles/00-00-00-00-86/Patch.tar
  • clem57
    clem57 over 7 years ago +2
    Thanks gam3t3ch for the link. That is a great idea for an IDE. Nano not so great for Python.
    DAB over 6 years ago +2
    Nice tutorial on getting started with Pycharm. DAB
  • ikostan
    ikostan over 6 years ago in reply to ikostan +2
    Actually I figured that out. Since I am using 64 bit Linux version, the last step should be as following: cp libpty.so /opt/pycharm-community-2020.2/lib/pty4j-native/linux/x86_64/ The main problem that…
  • colporteur
    colporteur over 4 years ago
    Can you tell me if PyCharm terminal support has changed?
    I moved away from using PyCharm to using Visual Studio Code (VSC) because of terminal support. Running the python script in Pycharm was only supported in the license version of the product and not in the educational version. Opening an external terminal window to run the script was the norm. After discovering I could click a button and execute the python scripts from the window I was editing the script, bam I was motivated to move to VSC.
    I miss the familiarity of pycharm. VSC has more overhead but to get the feature to run a script inside the editing window was great. I have perfected the process supporting VSC on a Raspberry Pi. I'm to entrenched to move now.
    Just curious.
  • raspgraph
    raspgraph over 4 years ago
    Got Pycharm 2021.2 working ok thank you. And Terminal works good without the above mods. Using local New Os Bullseye(32bit) on pi4. But the following comments come up :-
    1st
    Although described in above comments  how to remove this comment
    Unfortunately, JetBrains does not officially support native file watcher for this architecture. Please follow these instructions to compile it yourself.
    How can you improve file changes sync which it says may be slow?
    2nd
    Please consider switching to the bundled Java runtime that is better suited for the IDE (your current Java runtime is 11.0.13+8 by Raspbian at '/usr/lib/jvm/java-11-openjdk-armhf').
    Shall I do this?
    next Q how?
  • gam3t3ch
    gam3t3ch over 5 years ago in reply to raspgraph
    there ya go that should be what you want to disable there.
  • gam3t3ch
    just go to setting and then search for file watcher and turn it off..... since its on a arm device its going to happen.  Currently not at my pi but if you cant find it ill grab some images in a couple for you.
  • raspgraph
    raspgraph over 5 years ago
    Thanks for researching and solving Terminal issue. Good Job
    However the following still appear in Event Log (don't they also for you?)
    External file changes sync may be slow  ... native watcher not supported
    Consider Built in Java
