Raspberry Pi
Raspberry Pi
Blog issue with cirrus_audio.img on 16GB SD?
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: tonyhansen
  • Date Created: 3 Jan 2015 4:14 AM Date Created
  • Views 518 views
  • Comments 5 comments
  • b+
  • image
  • raspberry_pi
  • raspeberry_pi_accessories
  • boot
tonyhansen
tonyhansen
3 Jan 2015
I was unable to boot off of cirrus_audio.img when it was copied onto a couple different 16GB SD cards.
It works fine after being copied onto an 8GB SD card.
The old wolfson image installed and booted just fine on a 16GB SD card.
Not sure if anyone else has tried this. I was planning on eventually installing this on a 64 GB SD card (I have some on order), but am not sure at this point that I'll be able to do so.
Has anyone else been able to install the cirrus_audio boot image onto a 16 GB SD card or larger?
    e14 Contributor over 11 years ago in reply to tonyhansen +2
    I have tested 64GB SD-card without any problem. (SanDisk Ultra 64GB micro SDXC I with [RPi B+] + [CL audio card] as well as [RPi A+] + [CL audio card]).
  • tonyhansen
    tonyhansen over 11 years ago in reply to e14 Contributor
    TThat's a good data point. Thank you for verifying that.
  • tonyhansen
    All my 16GB SDs are class 10.
    e14 Contributor over 11 years ago in reply to e14 Contributor
    Fix: SDHC
    I did it without any problem. (I have used 16GB Kingston Micro SDHS 10x, wrote image by Win32DiskImager, and then expanded volume to full size of SD-card just in Raspbian.)
    I also planning to use 64GB SD card. I will report about this soon.
