Raspberry Pi
Raspberry Pi
Blog Messing about with the Raspberry Pi NoIR Camera
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: the48sicks
  • Date Created: 26 Nov 2017 7:39 PM Date Created
  • Views 1366 views
the48sicks
the48sicks
26 Nov 2017
For a moment, it felt like i was guiding the mars rover!
I bought the NoIR camera about 12 months ago for another project and wondered how i could incorporate into my robot somehow. I swapped out my normal camera that i use for my OpenCv work and dropped in the NoIR camera, Now in the past i have tried using some of the small IR lamps and LED units but they never really delivered the results i was looking for so i found an IR FLOOD LIGHT and mounted that on a deck for giggles to see how it would work and my word - the results were amazing! This thing lit up the place like a runway landing light.
To the human eye, you only see little red lights in the LED's but my android phone caught the full power of this thing.
The power for the flood light is switched by a relay mounted under the deck, but the unit also had a built in light detector, good for saving juice while running on batteries!
IR Still image
Trying to navigate around my apartment. Ive since tuned the motors so he runs a bit straighter
It would be cool if there was some way that i could easily switch between a normal and a noIR camera. I think its called an auto-switching or cut filter. at the moment i just have it blue tacked onto the front of the normal one and switch the ribbon between the two  image
    DAB over 8 years ago in reply to the48sicks +2
    What you are seeing is the sweat transfer through your shoe soles to the floor. The sweat retains the heat from your body that slowly dissipates as the sweat dries and the area cools. I look forward to…
  • the48sicks
    the48sicks over 8 years ago +1
    Raspberry Pi NoIR Camera side by side FLiR Lepton Thermal camera. I love the residual heat from my footsteps (excuse the pajamas!) players.brightcove.net/.../index.html
  • the48sicks
    the48sicks over 8 years ago in reply to DAB
    Thanks DAB - Might take a  look into it, see if there is a way i can mount a servo to switch it out
    I look forward to your future posts.
    PS, if you want to just see the IR with the NOIR camera, use a No.25 Red filter.  It will block everything below about 750 Angstroms leaving just the near IR wavelengths.
    You could use an IR block filter and a servo to drop it down in front of the camera when you just want regular RGB images.
  • the48sicks
