Raspberry Pi
Raspberry Pi
Blog MPIDE for raspbian
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Date Created: 13 Feb 2014 9:41 PM Date Created
  • Views 784 views
  • raspberry_pi
  • raspeberry_pi_accessories
MPIDE for raspbian
e14 Contributor
e14 Contributor
13 Feb 2014
Hello,
The chipkit_pi package already built is not fine for me because I can't extend the partitions like with the standard raspian image:2013-09-25-wheezy-raspbian.img.
So I would like to install first the original raspian image 2013-09-25-wheezy-raspbian.img and then download the MPIDE software on the raspberry pi in order to be able using the chipkit-pi board
How can I proceed ?
Thanks
    e14 Contributor over 12 years ago in reply to e14 Contributor
    Thanks a lot
    I made also a lot of research on the Web last veek and I got the same steps that yours
    The only minor differences are the following:
    1/ Change execution rights on PIC32 directory
    chmod +x -R ./pic32
    2/ Add user pi in the dialout group
    sudo usermod -aG dialout pi
    3/ Modify directly /boot/cmdline.txt and /etc/inittab instead installing and using rpi-serial-console
    dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
    #T0:23:respawn:/sbin/getty -L ttyAMA0 115200 vt100
    Eric
    Hi Eric,
    I went through the exercise of doing exactly this. I posted a procedure at:
      http://www.chipkit.net/forum/viewtopic.php?f=6&t=2802
    So got it working now and can run the example code supplied with MPIDE (at least the (modified) Blinking example code)
    Regards, Eric
