Raspberry Pi
Raspberry Pi
Blog My 3rd big Halloween Project - an actual nightmare
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Date Created: 28 Oct 2015 6:43 PM Date Created
  • Views 4139 views
  • Comments 17 comments
  • halloween
  • raspberry_pi
28 Oct 2015
A little background... here are my first two Halloween projects:
The Scary Door
The Scary Porch
Now my third one... In this project I want to control a ton of LEDs and output sound.  Sound I have covered, from the Scary Porch project. However, the LEDs are the nightmare.
I am currently using shift registers to address all the LEDs in the group, working on controlling 100 LEDs right now. A shift register take 1 output and turns it into 8. It's working, but this seems like a brute force way to attack the issue.
Here is a test:
It is not going as seemless as I wanted. Does anyone here have some suggestions on how to control hundreds of LEDs?
C
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago +2
    Do you want every one to be individually addressable ??, if so then neopixel (To Borrow an Adafruit brand name) will probably work best, if it is simply a few banks then perhaps a mosfet driver for each…
    Robert Peter Oakes over 11 years ago in reply to Catwell +2
    Yes Turn it into a Christmas / Winter Holiday themed project, now you have 2 months to finish
    balearicdynamics over 11 years ago in reply to Catwell +1
    Cabe, where did you bought the neopixels for this price? These are produced in China nad there are tons of producers of any kind that sell for a more reasonable price.
    With the neopixel, all you need is to provide a single data stream to the LEDs and power, with regular LEDs you have to build all the interface circuitry and wire it all to the LEDs, the NEOPIXEL has all this done for you
    so in monitary terms assuming the neopixel will give you the brighness you need (in addition to full RGB)
    if you can build all the interface serial shift registers etc in less than 88$ worth of time ???, with a neopixes, you provide power and a serial data in, and the out to the next pixel thats it
    so if you can wire all those led shift registers in an hour (Or 3 if your time is worth 30$ or less an hour, go for the high brighness LEDs ??
    I have played with the neo pixels and there great fun and so much you can do with them, just check out the Internet of Holiday Lights winners if you dont believe me image
    Cabe,
    Actually the neopixes (WS2812B can be a meter or more apart with ease, each chip repeats the previous through a buffer so sont dismiss them too easily, now if all your needing is white LEDs and not colour or different brighness then yes there overkill but not because of distance (Unless you want each LED a few meters apart ?, you have not said
  • Catwell
    Catwell over 11 years ago in reply to gadget.iom
    WS2812 is at 50cents each. Or $100 for 200 Neopixels. This is versus the $12 I paid for 200 ultrabright LEDs.
    What is the benefit of the Neopixel vs Traditional LEDs in a simple on and off circuit?
    Peter,
    Thanks for the chip suggestions... I think I might use those!
    C
    Just about the LEDs far apart, neopixels are sold in some different sizes small rings, tapes up to six meters long (if I am not wrong) and also as single, separate units that then you can join in your circuit / wiring as you prefer following your design and schema.
    Enrico
