Raspberry Pi
Raspberry Pi
Blog My 3rd big Halloween Project - an actual nightmare
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Date Created: 28 Oct 2015 6:43 PM Date Created
  • Views 4144 views
  • Comments 17 comments
  • halloween
  • raspberry_pi
28 Oct 2015
A little background... here are my first two Halloween projects:
The Scary Door
The Scary Porch
Now my third one... In this project I want to control a ton of LEDs and output sound.  Sound I have covered, from the Scary Porch project. However, the LEDs are the nightmare.
I am currently using shift registers to address all the LEDs in the group, working on controlling 100 LEDs right now. A shift register take 1 output and turns it into 8. It's working, but this seems like a brute force way to attack the issue.
Here is a test:
It is not going as seemless as I wanted. Does anyone here have some suggestions on how to control hundreds of LEDs?
C
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago +2
    Do you want every one to be individually addressable ??, if so then neopixel (To Borrow an Adafruit brand name) will probably work best, if it is simply a few banks then perhaps a mosfet driver for each…
    Robert Peter Oakes over 11 years ago in reply to Catwell +2
    Yes Turn it into a Christmas / Winter Holiday themed project, now you have 2 months to finish
    balearicdynamics over 11 years ago in reply to Catwell +1
    Cabe, where did you bought the neopixels for this price? These are produced in China nad there are tons of producers of any kind that sell for a more reasonable price.
    Do you want every one to be individually addressable ??, if so then neopixel (To Borrow an Adafruit brand name) will probably work best, if it is simply a few banks then perhaps a mosfet driver for each bank
    Can you describe better what your trying to build, how its going to work ?, trying to wire up multiple shift register chips will become very tedious if were talking hundreds so a better approach should be thought of
    looking forward to additional info
    Peter
    Shift registers is the right solution.
    https://www.tindie.com/products/alicemirror/daisy-chained-shift-registers-board-arduino-kit/
    This is a project initially done for Arduino but works also with the Raspberry PI. With this configuration it can support up to 32 different LEDs. In my opinion if you have really hundreds of LEDs to control easily you should approach a different way.
    I suggest as alternative, the use of a NeopixelNeopixel RGB LEDs strip that at a reasonable cost gives you the option to control several meters of chained LEDs probably already ready to fit in your project.
    An example of their usage, in this case with a ring is in the following Blog post: Meditech: Camera probe with PI camera As mentioned, in the bottom of this same post, fvan has published a very good tutorial on the use of the neopixel LEDs that can be found there: Sci Fi Your Pi: PiDesk - Guide: Controlling NeoPixels with the Raspberry Pi A+/B+
    Enrico
