Raspberry Pi
Raspberry Pi
Blog My homemade beowulf cluster underway
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: nschreiber0813
  • Date Created: 26 Jan 2017 4:52 PM Date Created
  • Views 896 views
  • beowulf
  • raspberry pi
  • raspberry pi 3 cluster
nschreiber0813
nschreiber0813
26 Jan 2017
Dear: Element 14 Community
I am letting you guys know I am building a raspberry pi cluster based off of a laser cut frame I designed and cut on a laser cutter and designed with librecad.
Let me just explain first of all my experiences as an engineer. Here are a list of accomplishments I have made within the past few years.
  • Built a video game for xbox 360 from XNA C#.
  • Built a 3D printer.
  • Built several robots with Arduino.
  • 3D printed a  ton of junk in my basement.
  • Working on a new 3D printer.
  • Did first robotics and learned netbeans ide.
  • and more...
I also have used a raspberry pi before. I recently got a raspberry working with an lcd display and raspbian. Here are a list of parts I need to continue the project.
  • 60 * m2.5 X 15mm bolts.
  • 15 * RPi3
  • A ton of Ethernet cables
  • A 15 usb port usb bus
  • A 15 Ethernet port Ethernet bus
  • usb micro cables.
I would also need to accomplish the following.
  • Powering 15 raspberry pis.
  • Getting 15 raspberry pi's in a  cluster.
  • Mounting and keeping things organized in the cluster.
  • Program a code breaking algorithm.
Wish me good luck!!! Thanks!!!
  • rachaelp
    rachaelp over 9 years ago +1
    Good luck Noah, keep us posted with how you get on!
  • Workshopshed
    Workshopshed over 9 years ago +1
    Hi Noah, you might find it easier to power the Pi using a regulated supply (perhaps a big PC PSU) connected to the expansion headers, pins 2,4 (5v) and 6 (gnd). http://pinout.xyz/ #
  • bitscope
    bitscope over 9 years ago +1
    Hi Noah, Very interested to learn how you get on with this! You might find BitScope Blade Quattro BitScope Blade Quattro build as a cluster pack is a good way to power and mount them all: We're posting…
  • bitscope
    Hi Noah,
    You might find BitScope Blade QuattroBitScope Blade Quattro build as a cluster pack is a good way to power and mount them all:
    Image result for bitscope cluster pack
    We're posting more info about blade related products and applications in the community over the coming weeks.
    DM me if you have questions.
    Cheers, Bruce.
  • Workshopshed
    http://pinout.xyz/#
  • nschreiber0813
    nschreiber0813 over 9 years ago in reply to rachaelp
    Thanks I will need it. You are awesome!!!
  • rachaelp
