Raspberry Pi
Raspberry Pi
Blog My Raspberry Pi 4 does not boot?
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: clem57
  • Date Created: 21 Oct 2019 2:20 PM Date Created
  • Views 10175 views
  • Comments 7 comments
  • raspberry pi 4 b
clem57
clem57
21 Oct 2019
Recovery
If your Raspberry Pi 4 will not boot, it is possible that the SPI EEPROM has become corrupted.
To check, remove the SD card, disconnect the device from power, then reconnect it. If the green LED does not flash, you will need to reprogram the EEPROM:
  1. Download the bootloader
    imageSHA-256: 2c5610682edfa2c3a2a41832c687559d8f091b9e48abaeb8577cca2a0cc81839
  2. Extract it to an empty FAT-formatted SD card and insert it into your Raspberry Pi 4
  3. Connect the power and wait for the green LED to flash quickly
Notes:
  • The updated bootloader improves compatibility with HATs by changing the behaviour of HALT to keep the 3V3 pin powered (view the full bootloader release notes)
  • The previous bootloader remains available for download
  • clem57
    clem57 over 6 years ago in reply to cstanton +1
    I believe this is an area where they might add new features and other possibilities. And this is a departure from the past reliance on the SD card. We will have to wait and see ... Clem
  • cstanton
    cstanton over 6 years ago in reply to tony1959 +1
    Have you made sure that you're using a good quality 5v 3amp power supply for it?
  • ferace
    ferace over 6 years ago in reply to tony1959
    Multiple I2C on GPIOs
    Hi! I had the same problem with rpi4 after upgrading to the new OS system. I found out that the use of multiple i2c on the gpios causes the system to stop under booting process. When I left only one i2c on
    GPIO 2 and 3 it boot without problems, but only one i2c!
    I hope this can help you.
  • cstanton
  • tony1959
    tony1959 over 6 years ago in reply to tony1959
    Nope,
    I think I blew the pi up.....
  • cstanton
    This thread doesn't exactly match your problem. You may be better off starting a new thread.
    Does the Raspberry Pi OS (Raspbian) boot from an SDCard in the Raspberry Pi 4?
  • tony1959
    Hi,
    I have this problem too, that my pi4 does not boot.
    If I power it up with no SD card, I get the message no SD card found. Which is obviously correct.
    The green led flashed 4 times, off for longer and then flash 4 times etc, I think indicating it is searching for a device to boot from.
    If I power it with SD card (latest UBUNTU image, lts 20xxx) the green led lights up, and flashes once, and then it is off.
    On the connected screen there is no signal received (none at all: no blink or blank or whatever).
    I replaced the bootloader already - the one downloadable via the Raspberry Pi Imager (v1.2). But no improvement.
    The same sd card in a different (Pi3) boots fine.
    Tried different power sources already, but no result.
    Can anyone advise?
    Ton
