Raspberry Pi
Raspberry Pi
Blog My Very First Ever Python Programme and on a Raspberry Pi
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: dubbie
  • Date Created: 14 Mar 2020 1:08 PM Date Created
  • Views 3558 views
  • Likes 8 likes
  • Comments 18 comments
  • python;
  • rpi-bc
dubbie
dubbie
14 Mar 2020
I wished to join the Raspberry Pi day activity so I decided that I would combine this with writing my very first own Python programme as well. I recently did an online Python course which had some directed programmes in but I wanted to make up my own unassisted. As I am shortly going out for lunch this had to be very short so I decided on
print("Hello and Happy Pi Day")
Next I needed my Raspberry Pi which is still integrated into my HoloPiBot (HoloPiBot #10 : It Actually Works - It Really Does! ) so I just plugged in cables, keyboards, mouse and eventually power supply  (when I found it!) as I vaguely remembered how to do. Turned it on and amazingly it still all worked. I must have learned something after all. There is a bit of video of this, but the battery on my camera ran out - it doesn't seem to be charging so I might need a new camera - and this is all I captured.
Following this I needed to start Python. I had no idea whether my Pi had Python so I decided to Google it, using my Pi, of course. Seems that it does have Python so I just went to the command line, typed in Python, then the programme above and it worked! If I have time over this weekend I might now try flashing an LED on and off - no promises though.
The Power of computing.
Dubbie
  • airbornesurfer
    airbornesurfer over 6 years ago in reply to dubbie +4
    Sudo ("superuser do") is basically the shorthand for all elevated privileges in Linux. Or, as Randall Munroe so eloquently illustrated:
    beacon_dave over 6 years ago in reply to dubbie +4
    You may find this MagPi beginner's guide on the Python GPIO Zero library of interest: https://www.raspberrypi.org/magpi-issues/Essentials_GPIOZero_v1.pdf
    shabaz over 6 years ago in reply to beacon_dave +4
    With newer versions of Python 3, there's another option too - really nice: import math print(f"Hello and Happy {math.pi} Day") The Jive syntax highlighting has not kept up though! : )
    dubbie over 6 years ago in reply to clem57
    Clem,
    This also makes sense. However, if I can give myself permission to use the hardware level, it doesn't seem to confer much protection. Is it like being Administrator in Windows?
    Dubbie
    dubbie over 6 years ago in reply to airbornesurfer
    Matthew,
    That's make sense.
    Dubbie
    dougw over 6 years ago
    vid-19 strikes again
  • clem57
    clem57 over 6 years ago
    # Python code to reverse a string
    # using extended slice syntax
    # Function to reverse a string
    def reverse(string):
    string = string[::-1]
    return string
    s = "yaD iP yppaH"
    print ("The original string is : ",end="")
    print (s)
    print ("The reversed string(using extended slice syntax) is : ",end="")
    print (reverse(s))
    dubbie  try this code and see how recursion works...
