Raspberry Pi
Raspberry Pi
Blog NO Network with Pi 2
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Date Created: 21 May 2015 2:03 PM Date Created
  • Views 1115 views
  • Comments 5 comments
  • raspberry_pi_space
e14 Contributor
e14 Contributor
21 May 2015
Hi,
I have a to me strange problem and could use some help. I have two raspberry Pi's a model B+ and a model 2. I can hook up the B+ and every thing works just fine but if I connect the model 2 it does not show up in my home network. Like I said the model b+ works fine I can see it from my windows computer and I can add movies and music with no problems. But if I hook up the model 2 I see nothing yet I can connect to the internet using either one. I have them both set to the same IP address and subnet mask on my xfinity router the only difference is the Mac address.I have tried reformatting and reinstalling my Windows computer twice and same thing other pc's like Laptops and I Pads connect fine just not my raspberry Pi model 2.
Any thoughts would be much appreciated
               Thanks
                         Russ
    e14 Contributor over 11 years ago in reply to balearicdynamics +1
    And of course, mask any publicly accessible information(though I only see this as an internal machine in most applications). ;-)
    First of all, are you networking with Ethernet or Wifi-over-USB?  The answer to this question will tell us which config files to look at.
    What networking products are you using with the 2 Pis?
    Please execute `cat /etc/network/interfaces` and post the output to this thread.
    balearicdynamics over 11 years ago in reply to balearicdynamics
    Completing as for what wrote clem57
    ifconfig can't be executed as user, it seems not existing. use sudo ifconfig
    Hello,
    with the very few information that you have provided, I think it is almost probable depending by software than hardware. Please make a couple of simple troubleshooting, just to be sure of the scenario.
    • When you connect the ethernet cable, do you see the yellow led just on the network plug lighten ?
    • Please execute the following command and post the result:
    $>iptables
    $>ping -c 5 www.google.com
    $>ping -c 5 8.8.8.8
    Then, please send the content of the file /etc/network/interfaces
    Thank you.
  • clem57
    clem57 over 11 years ago
    Please do this command on both B+ and model 2:
    ifconfig
    and post results here.
    Also check if you have Samba installed and enabled on both correctly.
    Clem
