Raspberry Pi
Raspberry Pi
Blog Pi Camera Board Photography Competition
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Date Created: 28 May 2013 3:27 PM Date Created
  • Views 672 views
  • raspberry_pi
e14 Contributor
e14 Contributor
28 May 2013
I have been desperate to get my hands on a Raspberry Pi camera module for a project and ended up having to use a USB which caused me some concern as the power requirements of some of the USB ones mean that you can't run them alongside a wifi dongle like my WiPi. Fortunately I managed to procure a Logitech C110 to tide me over until my PiCam arrives and now Duck Cam is up and running.
I started with one of my four Raspberry Pi and the latest image file. The webcam and WiPi both worked out of the box and all was looking good. I installed ffmpeg from the repo to stream to bambuser.com using RTMP but it kept failing after a single frame.
Getting the latest source from git and compiling my own ffmpeg meant that it then worked perfectly and using my cheap cam I have managed to stream up to 640x480 at 15fps (that's all this cam can do). I am lookng forward to getting a PiCam so I can up the resolution and frame rate to the limits of my home internet connection.
For those that want to do something similar you'll need to follow these instructions to compile ffmpeg and then sign up for a bambuser account and follow these instructions to get the streaming working.
So what am I streaming? My wife and I are currently looking after two cayuga ducklings called Bramble and Dandelion so I have rigged up their box with the RPi and camera as seen below.
The resulting stream can be seen at http://bambuser.com/channel/duckcamuk
    I made some tweaks today so that ffmpeg runs in a loop
    while true
    do
         ffmpeg ...
         echo "Restarting in 1 minute"
         sleep 60
    done
    I also put the script in /etc/init.d so it runs at boot time. The 60 second sleep is there because without it you risk annoying the hell out of bambuser.com. With this script I should have far greater uptime and it means when my wife takes the ducks to school all she needs to do is plug in the power for the RPi and the camera stream will come up automatically.
