Raspberry Pi
Raspberry Pi
Blog Pi case mini mod for low profile microSD adapter
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: fvan
  • Date Created: 8 Jan 2014 9:21 PM Date Created
  • Views 1183 views
  • Comments 6 comments
  • microsd
  • raspberry_pi
  • enclosure
  • raspberrypi
  • case
fvan
fvan
8 Jan 2014
I like to avoid peripherals and accessories of the Raspberry Pi sticking out too much, resulting in a cleaner look. One of those things "bothering" me, is the SD card.
There are alternatives, such as the low profile microSD card adapter from Adafruit. Unfortunately, since it's thicker than a normal SD card, it does not always fit in the case.
That's why I modified my case to allow the use of such an adapter.
I carved out the bottom of the case to compensate for the extra thickness of the adapter.
I also had to provide a little more space in the other part of the case because the microSD sticks out a bit and is positioned lower than the normal SD card slot.
The result: the modifications made to the case are not visible from the outside and no SD card sticking out.
  • Problemchild
    Problemchild over 12 years ago in reply to mcb1
    These work well in the most part got 10 for like£6 from EBAY
    mcb1 over 12 years ago in reply to e14 Contributor
    I brought two of these to use.
    Blue Shortening microSD card adapter for Raspberry Pi & Macbooks ID: 1569 - $5.95 : Adafruit Industries, Unique & fun DI…
  • fvan
    fvan over 12 years ago in reply to e14 Contributor
    Does that work for every SD card ? I guess you can always shine a light behind the card and see image
    I've also come across a different adapter that is short and lower than Adafruit's "low" adapter: http://shop.pimoroni.com/products/compact-microsd-adaptor
    you could cut the plastic in half cause most sd plastic ''thingies'' are twice as big as the actual sd itself. (sorry for bad english)
  • Problemchild
    Agreed, although Adafruit should be referring to them as short rather than low-profile since they are just as deep really but
    the main benefit is the "shortness" of the adaptor
