Raspberry Pi
Raspberry Pi
Blog Pi Rack Connect Four Challenge
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Date Created: 3 Sep 2013 8:03 PM Date Created
  • Views 1773 views
  • pi_rack
  • led
  • raspberry_pi
  • document_camera
  • rpi
  • raspberry_pi_camera
  • raspivid
e14 Contributor
e14 Contributor
3 Sep 2013
I used a Raspberry Pi along with a PiRack, a Raspberry Pi camera module, a portion of a Pi Cobbler Kit, and a white LED to create a document camera for use in a high school classroom.  Document cameras typically cost hundreds of dollars.  Public school budgets are tight these days.  This RPi + PiRack + RPi camera module is an affordable solution that works with existing classroom technology (the projector that is already installed).  From the command line: sudo raspivid -t 0 -fps 20 -br 66 gives a nice image. At a height of around 13" above the document being examined, the document camera makes the writing on half of a letter-sized sheet of paper visible to all students in the classroom.  The older ceiling-mounted projector accepts composite video input.  This works fine.  Better viewing results could be obtained with a modern projector that had HDMI inputs.
  • paulijennifer
    paulijennifer over 3 years ago
    Great job, at school we also did a similar project.
    Studying takes up a lot of time and you often don't have time to do your favorite things. Fortunately, I read an article about essay pro and now I have more time for my hobbies and various school projects.
  • Problemchild
    Problemchild over 12 years ago in reply to mcb1
    This is quite a ingenious   use of the Pi and camera!!
    mcb1 over 13 years ago
    Nice use.
    Well done
