Raspberry Pi
Raspberry Pi
Blog Raspberry Pico as USB test device - part 4: Python PyVISA test bed
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Date Created: 5 Feb 2023 9:09 AM Date Created
  • Views 4139 views
  • raspberry
  • pico_usbtmc_scpi
  • pico
  • scpi
  • pyvisa
5 Feb 2023
In this post, I test the USBTMC and SCPI compliant instrument I developed for the Pico.
I use a PyVISA script to check if the instrument is connected. Then the outputs are switched and validated.
The test scenario:
  • check if there's an instrument available
  • validate the *IDN? string
  • reset
  • test all pins
Helper functions
*IDN? validation:
def test_idn():
    isPico = False
    idn = inst.query("*idn?");
    print(idn)
    # check if the IDN string matches the expected pattern. Allow for different serial number
    if(re.search("PICO-PI,LABSWITCH,\d+,01.00\r\n", idn) != None):
        isPico = (inst.is_4882_compliant)
    return isPico
control a pin:
def set_pin(pin, on):
    cmd = "DIGI:OUTP{} {}".format(pin, on)
    inst.write(cmd)
get pin status:
def get_pin(pin):
    cmd = "DIGI:OUTP{}?".format(pin)
    return inst.query(cmd)
test a pin:
def test_pin(pin):
    print("Status of pin {} before setting: {}".format(pin, get_pin(pin)))
    set_pin(pin,1)
    print("Status of pin {} after setting: {}".format(pin, get_pin(pin)))
    time.sleep(1)
    set_pin(pin,0)
    print("Status of pin {} after resetting: {}".format(pin, get_pin(pin)))
The test program
The test code uses the functions above to validate settings, and loop over the pins:
#!/usr/bin/env python3
import pyvisa as visa
import time
import sys
# the functions from the previous section sit here
rm = visa.ResourceManager()
reslist = rm.list_resources("USB?::?*::INSTR")
print(reslist)
if (len(reslist) == 0):
    sys.exit()
i = 0
inst = None
while i < len(reslist):
    inst = rm.open_resource(reslist[i]);
    inst.timeout = 3000
    inst.clear()
    print("+ IDN")
    if(test_idn()):
        print("Instrument found")
        # reset
        inst.write("*RST")
        # test 3 pins
        j = 0
        while j < 3:
            test_pin(j)
            j += 1
    print("SCPI errors during test: "+ inst.query("SYST:ERR:COUNT?"))
    inst.close()
    i += 1
print("Test complete")
The skeleton of this test is taken from the TinyUSB USBTMC Python unit test.
Test output:
PS C:\Users\jancu\Documents\Pico\my_examples\scpi_switch_usbtmc> & C:/Users/jancu/AppData/Local/Microsoft/WindowsApps/python3.9.exe c:/Users/jancu/Documents/Pico/my_examples/scpi_switch_usbtmc/test/visaQuery.py
('USB0::0xCAFE::0x4000::123456::INSTR',)
+ IDN
PICO-PI,LABSWITCH,0,01.00
Instrument found
Status of pin 0 before setting: 0
Status of pin 0 after setting: 1
Status of pin 0 after resetting: 0
Status of pin 1 before setting: 0
Status of pin 1 after setting: 1
Status of pin 1 after resetting: 0
Status of pin 2 before setting: 0
Status of pin 2 after setting: 1
Status of pin 2 after resetting: 0
SCPI errors during test: 0
Test complete
During the execution, each of the 3 pins will be set high for a second, then set back to low. You can test that with LEDs or a DMM.
Python code
import time
import sys
import re
def test_idn():
	isPico = False
	print(idn)
	return isPico
	inst.write(cmd)
def get_pin(pin):
def test_pin(pin):
	set_pin(pin,1)
	time.sleep(1)
	set_pin(pin,0)
print(reslist)
    sys.exit()
i = 0
inst = None
	inst.timeout = 3000
	inst.clear()
	print("+ IDN")
	if(test_idn()):
		# reset
		inst.write("*RST")
		# test 3 pins
		j = 0
		while j < 3:
			test_pin(j)
			j += 1
	inst.close()
	i += 1
visaQuery_20230205.zip
link to all posts
    DAB over 3 years ago
    Good post Jan.
    Jan Cumps over 3 years ago
    VSCode detected that this was the first Python file I made since the installation. It suggested to install the Python extension.
    This immediately gives colour highlighting, auto-complete, output capture, run and debug functionality. Neat.
