Raspberry Pi
Raspberry Pi
Blog Raspberry Pi 3 HTML Control Interface Part 3
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Date Created: 17 Oct 2016 6:22 PM Date Created
  • Views 1176 views
  • raspberry pi3
  • rpi_3
  • raspi3
e14 Contributor
e14 Contributor
17 Oct 2016
This part focusses on controlling the gpio pins of the Pi using a web based user interface. Ive kept everything as simple as possible and also kept the page layout simple too.
Step 1
The webserver running on the Pi3 needs permission to access the gpio pins, this can be done easily by adding the webservers user account (www-data) to the gpio group
sudo adduser www-data gpio
now the pins can be controlled without the need of root permissions which makes things so much easier
Step 2
We need to create some Python scripts to run the Bash commands that controls the gpio pins, its likely that in a final application all of these commands will be put into a single Python file but to keep things segmented at this stage, a seperate file for each command was used. When Python files are added to the cgi-bin on the webserver make sure to use chown to change the owner of the file to the www-data user and chmod to make the files executable.
gpiodirectionin.py
#! /usr/bin/python
import os
import sys
os.getenv("QUERY_STRING")
pinnumber = sys.stdin.read()
p = os.popen("echo in > /sys/class/gpio/gpio"+pinnumber+"/direction")
p.close()
print "Content-Type: text/html\n\n"
print '<html><head><meta content="text/html; charset=UTF-8" />'
print "</body></html>"
gpiodirectionout.py
import os
import sys
p = os.popen("echo out > /sys/class/gpio/gpio"+pinnumber+"/direction")
p.close()
gpioexport.py
#! /usr/bin/python
import os
import sys
p = os.popen("echo "+ pinnumber  +" > /sys/class/gpio/export")
p.close()
gpiounexport.py
#! /usr/bin/python
import os
import sys
p = os.popen("echo "+ pinnumber  +" > /sys/class/gpio/unexport")
p.close()
gpiovaluehigh.py
#! /usr/bin/python
import os
import sys
p = os.popen("echo 1 > /sys/class/gpio/gpio"+pinnumber+"/value")
p.close()
gpiovaluelow.py
#! /usr/bin/python
import os
import sys
p = os.popen("echo 0 > /sys/class/gpio/gpio"+pinnumber+"/value")
p.close()
Step 3
Rather than use the index.html file from the previous 2 blog posts, I made a new webpage to keep it easy to read. It contains a text field for a user to enter the gpio pin number to control and buttons to operate the pin exporting, direction control and set the high or low. The buttons call javascript functions which interact with the Python scripts above.
gpio.html
<html>
<body>
<input type="text" id="pinnumber" style="font-size:2.0em;" maxlength="2" size="1" value="1">
<input type="button" onClick="exportPin()" value="Export">
<input type="button" onClick="unexportPin()" value="Unexport">
<input type="button" onClick="setDirectionOut()" value="Set Output">
<input type="button" onClick="setPinHigh()" value="Set High">
<input type="button" onClick="setPinLow()" value="Set Low">
<script>
function exportPin(){
    var pinnumber = document.getElementById("pinnumber").value;
    var req = new XMLHttpRequest();
    req.open("POST","/cgi-bin/gpioexport.py",true);
    req.send(pinnumber);
function unexportPin(){
        req.open("POST","/cgi-bin/gpiounexport.py",true);
function setDirectionOut(){
        req.open("POST","/cgi-bin/gpiodirectionout.py",true);
function setPinHigh(){
        req.open("POST","/cgi-bin/gpiovaluehigh.py",true);
function setPinLow(){
        req.open("POST","/cgi-bin/gpiovaluelow.py",true);
</script>
</body>
</html>
There's a video demonstrating the use of this system below, any questions please ask them in the comments and keep a look out for a follow up blog post showing how we can use the pins as input pins and display their values in the webpage!
    e14 Contributor over 9 years ago in reply to DAB +2
    Yes, that's a good idea; my voice is an absolute nightmare to record! A video I did yesterday might as well have been a silent movie, I had to provide a voice track for it to be edited with! A couple of…
    A couple of weeks ago I was speaking on a radio show and they had to turn everybody elses microphones down and gain the master volume right up to make my voice level with everybody elses!
    DAB over 9 years ago
    Hi Lucie,
    I would suggest you get a clip on microphone.
    Your voice just does not carry to the camera on these videos.
    Thanks
