Raspberry Pi
Raspberry Pi
Blog Raspberry Pi B+ In Pictures
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: Problemchild
  • Date Created: 16 Jul 2014 3:24 PM Date Created
  • Views 2205 views
  • Comments 6 comments
  • b+
  • raspberry_pi
  • rpi
Problemchild
Problemchild
16 Jul 2014
My Raspberry Pi B+ arrived yesterday so I thought I'd take a few photos of both the B+ and the changes but also how existing boars do do not fit the B+ design!
PI+  Full Frontal image
B+ Network (now with Blinkin' Lights) and the all important 4 USB ports
New 4 port USB Variant of the original 2 port device, Composite Phono has gone to be replaced with a 4 pole AV combo on the other side
The Rear has been tided up and the full sized SDcard is replaced with a nice metal  micro SD push push device!
The Micro USB power connector is now on the same side as the HDMI and the Linear regulators replaced by this Switch mode.
Expect lower supply currents and hopefully reliability !!
Small CISECO Radio board fits easily no problems
Unfortunately a no go with The PI Face Control and Display
Same for the Pi Face Digital
Adafruit's Prototyping board stands higher and thus is free of the board underneath and fits fine
(All images My copyright)
As you can see they a have taken many of the problems that existed in the B and have mitigated them in the B+.
The B+ is a true incremental release in this respect the extra USB ports and SMPs PSU should improve functionality and reliability.
Overall the physical layout changes are a great improvement  having connectors on only two sides will aid case designers and integrators alike. Large boards do foul the connectors some redesign is required for these (maybe a physical lift upwards??)
Extra I/O on the 40 pin connector should prove interesting as well!!
  • Problemchild
    Problemchild over 12 years ago in reply to shabaz +1
    Good idea also maybe having longer spills on the connector so it was proud of the connectors would be a move too. Damn we are planning a Pi B++ already
  • johnbeetem
    johnbeetem over 12 years ago in reply to mcb1 +1
    mcb1 wrote: So does anyone know what the two pin (unpopulated) connector labelled 'RUN' is for. (Its between the Display connector and ACT led at the edge of the board.) It's probably the same…
  • Problemchild
    Problemchild over 12 years ago in reply to mcb1 +1
    It's also in the Compute Pi documentation as well. Worth a look in general to find out a number of strange pins brought out and named on this device !
    shabaz over 12 years ago
    I see the raspberry logo has been thickened up too, looks cleaner now. It's good to see that finally some details matter on this board! : )
    One thing that would have been worth doing is little silkscreen markers at the 10-pin points on the board at the GPIO connector, like the BeagleBone Black has. It is very convenient to quickly know you're using the pin you intended :-)
