Raspberry Pi
Raspberry Pi
Blog Raspberry Pi now with OpenCL GPU Support (VC4CL VideoCore IV OpenCL)
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: cstanton
  • Date Created: 22 Jan 2019 3:53 PM Date Created
  • Views 10317 views
  • Likes 8 likes
  • Comments 6 comments
  • raspberry pi opencl
  • videocore iv
  • open cl
  • opencl
  • raspberry pi
  • vc4cl
cstanton
cstanton
22 Jan 2019
Next Biggest Breakthrough for Raspberry Pi is here!
Today I successfully compiled OpenCL on raspberry pi 3, Opening the door for numerous GPU possibilities for Raspberry Pi, Love the performance in FFMPEG(1080p rendering) and now looking forward to Deep-Learning applications on this little beast.
VC4CL is a newer effort bringing OpenCL to the Broadcom VideoCore IV GPUs as found in the Raspberry Pi boards. VC4CL implements OpenCL 1.2 for the VideoCore 4 graphics processor albeit the embedded profile standard. This VC4CL implementation does support the OpenCL ICD.
Notable supported features:
- Performance-wise it beats the results of the pocl implementation for the floating-point benchmark (reaching up to 4GFLOPS!) and has an expected inferior memory-access speed (at up to 120MB/s). More info. here
- 64-bit data-types (long, double)
- Active development
More Information on this Project can be found here: https://github.com/doe300/VC4CL
Kudos to all the project DEVS!!!
Source: https://www.reddit.com/r/raspberry_pi/comments/ailmgj/raspberry_piopenclgpu_vc4cl_videocore_iv_opencl
VC4CL Performance Details: https://github.com/doe300/VC4CL/wiki/Performance
VC4CL Github: https://github.com/doe300/VC4CL
  • cstanton
    cstanton over 7 years ago in reply to zhaod
    zhaod , I recommend you raise an issue on the github repo.
  • zhaod
    zhaod over 7 years ago in reply to cstanton
    Thank you very much for your reply.
    According to the guide of https://github.com/doe300/VC4CL/wiki/How-to-get, I successfully install VC4C, VC4CL and VC4CLStdLib. But I found the error when calling function clBuildProgram to build kernel, the forllowing is detailed error information.
    symbol lookup error: /usr/local/lib/libVC4CL.so: undefined symbol: _ZN4vc4c11Precompiler10precompileERSiRSt10unique_ptrISiSt14default_deleteISiEENS_13ConfigurationERKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEERKNS_8OptionalISD_EESH_
    But I also find the symbol in libVC4CC.so and libVC4CL.so, the following is detailed information:
    pi@raspberrypi:~ $ nm /usr/local/lib/libVC4CL.so | grep _ZN4vc4c11Precompiler10precompileERSiRSt10unique
             U _ZN4vc4c11Precompiler10precompileERSiRSt10unique_ptrISiSt14default_deleteISiEENS_13ConfigurationERKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEERKNS_8OptionalISD_EESH_
    pi@raspberrypi:~ $ nm /usr/local/lib/libVC4CC.so | grep _ZN4vc4c11Precompiler10precompileERSiRSt10unique
    00842780 T _ZN4vc4c11Precompiler10precompileERSiRSt10unique_ptrISiSt14default_deleteISiEENS_13ConfigurationERKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEERKNS_8OptionalISD_EESJ_
    Could you give me some suggestion to solve this issue? Thank you. Look forward to your reply.
  • cstanton
  • zhaod
    I download VC4C and VC4CL from github( https://github.com/doe300/VC4CL), but the Raspberrypi still can't run OpenCL. When I call function clGetPlatformIDs, the return value is -1001. How do you install VC4C and VC4CL or set which parameters on Raspberrypi. My machine type is Raspberry PI 3 Model B Plus Rev1.3. Could you help me? Thank you very much.
  • vimarsh_
    vimarsh_ over 7 years ago
    if we use GPU with OpenCL then what will be the benefit in time or resource while doing a little bit of image recognition?
