Raspberry Pi
Raspberry Pi
Blog Review: XBMC Solution
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: ryanteck
  • Date Created: 8 Jun 2013 9:26 AM Date Created
  • Views 1317 views
  • Comments 5 comments
  • raspberry
  • raspi
  • raspberry_pi
  • raspberrypi
  • xbmc
ryanteck
ryanteck
8 Jun 2013
This Thursday I was asked by element14 to test and review their new XBMC Solution and here it is!
The XBMC Solution is a kit that is designed to go with the Raspberry Pi to have a quick media center out of the box solution, it includes the following:
  • 4GB Class 4 SD card with Raspbmc already on it.
  • An Enthernet / Network Cable
  • A HDMI Cable
  • And an awesome wireless keyboard with built in touchpad!
  • Instructions on how to set it up.
You will also require:
  • Raspberry Pi Model B (I used a Rev 1 256MB, while it works fine sometimes it can take time to load some parts)
  • Power Supply (I'm powering it off of my TV).
I plugged it into our main TV using the HDMI and Enthernet cables provided, I am running the power via the TVs built in USB port (As the TV is a "Smart TV", this will be my comparison.)
The first boot takes a while as Raspbmc will update, I think it took around 10 Mins to fully update then it loaded!
The system has two configuration tools, one being the Raspbmc configurator that allowed me to bump up the overclock a little and the other being the XBMC setup.
I setup the time and turned on the HTTP / Web Server (Allowing me to control it via my phone).
Next I installed the youtube addon via the Addon section in videos. After installing I was able to play youtube videos! (The picture below is me playing my Raspberry Pi Bigtrak Jr Video via the Youtube Plugin).
The quality ran in 720p and can even run some videos in 1080p if configured to use it. You can also set it so it can only play up to 720P or Standard for if you have slower internet or a lower resolution TV.
And that is pretty much it, its a great kit and is just plug and play with little configuration needed. I did find quite a few benefits:
  • From where the remote is a full QWERTY keyboard it makes it quick and easy to search youtube compared to my TV which requires me to type it in slowly a char at a time.
  • Not all youtube videos are fully available via the TV's youtube app. This is from where youtube allows publishers to disable it (Mainly music videos). Raspbmc is therotetically a media center program for a computer allowing it to play most youtube videos.
  • Lots of applications and adddons can be installed.
Currently I am watching my favorite chiptune videos and demos via the Youtube app. I can even use my phone as the remote!
Thanks to Element 14 / Farnell / CPC/ Newark to let me review it! Also check out http://raspbmc.com the site of Raspbmc by Sam Nazarko!
Also check out my website @ http://blog.ryanteck.org.uk
    e14 Contributor over 13 years ago in reply to bad_boy_y
    Thank you very much bad_bo_y all sorted now.
  • bad_boy_y
    bad_boy_y over 13 years ago
    You carn powered your pi with a usb from you Tv to power it up when the tv are on and you need to plug the pi in HDMI for power down with your remote control. Mabay you have some seting in your tv for everyting work good.
    Hi,I'm new to all this and ive got my Pi up and running with the Raspxbmc software but i cant power it off my tv.I have a Samsung smart tv but it doesnt power the Pi up when i turn it on and i have to plug in the power adapter to the mains.Any help would great,thanks Rob.
  • ryanteck
    ryanteck over 13 years ago in reply to e14 Contributor
    Erm no it is wireless?
    The wire is used to charge it up. Are you sure that the dongle is not stored in the back compartment?
    Got the XBMC Bundle, and a Pi, plus a 3rd pty. case (nice sturdy white plastic, precut holes - snaps together nicely, good job dude!) to go with it. Tiny little Pi...goody goody...
    HOWEVER BE WARNED THAT as shipped, the "wireless" keyboard comes WITH A WIRE. That's not such a bad thing, since the expected (and pictured in the box) USB bluetooth dongle IS NOT PRESENT. As such, it might more properly be spoken of as a dongleless WIRED keyboard, sold to delay construction and negatively impact that good-'ol-out-of-box experience. Bah.
    - L, who appreciates truth in packaging, now has another dang thing to BUY. And WAIT for.
