Raspberry Pi
Raspberry Pi
Blog RP2040 SD Card SPI Benchmark Revisited
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: ralphjy
  • Date Created: 26 Mar 2022 10:13 PM Date Created
  • Views 4089 views
  • sparkfun_rp2040_mikroBUS_dev_board
  • spi
  • sd_card
  • rp2040
  • xiao_rp2040
ralphjy
ralphjy
26 Mar 2022
For Pi Day, I tried benchmarking the SD card interface on a new SparkFun RP2040 mikroBUS Development Board that I had just gotten - RP2040 SD Card SPI Benchmark.
I was somewhat disappointed in the results - around 140KB/Sec Write and Read.
LeScherd commented that he had been able to achieve around 2MB/Sec using a Pi Pico with a hand wired interface to an SD card socket.  I had used the benchmark example that was included with the SDFat library and he had used a somewhat customized program that tweaked the SPI clock frequency and the processor voltage.  He gave me a copy to try and while my results improved, they were still far short of his.  With this program I got around 250KB/Sec.
Of course there are quite a few variables in play.  I am using a SanDisk Ultra 16GB SD card and he is using a SanDisk Extreme Plus 32GB.  I would not have expected my card to be the limiting factor and he also got over 1.5MB/Sec using a ONN (Walmart brand) 32GB card.
The boards are certainly different - The SparkFun board uses SPI1 for the SD card and Bill used SPI0 in his setup.  Maybe I need some extra configuration?
I realized that I have another SD card setup, a Xiao expansion board, and I also happen to have a Xiao RP2040 that I haven't tried.  I checked the schematic and the expansion board uses SPI0 for the SD card.
So, time for some experiments...
Here's the expansion board setup.
And the results.  I included a standard Xiao (SamD21 - M0) on the same expansion board for reference.
Board Processor Bench Test  SPI interface Write KB/s  Read KB/s SD Card
Pi Pico RP2040 Modified 0 2010 2100 Sandisk Extreme Plus 32GB
Sparkfun MikroBus RP2040 Stock 1 143 143 SanDisk Ultra 16GB
Sparkfun MikroBus RP2040 Modified 1 255 255 SanDisk Ultra 16GB
Xiao + Expansion SamD21 Stock 0 369 355 SanDisk Ultra 16GB
Xiao RP2040 + Expansion RP2040 Stock 0 476 479 SanDisk Ultra 16GB
Xiao RP2040 + Expansion RP2040 Modified 0 769 768 SanDisk Ultra 16GB
I guess it just shows me that if it really mattered, I should test the SD card speeds in a specific configuration.  I should probably try some other SD cards in my RP2040 configurations (I don't have an Extreme Plus).  Maybe I should try to wire an SD socket to a Pico and see if I can reproduce Bill's results Relaxed.
  • mp2100
    mp2100 over 4 years ago
    You really have to read the spec sheets, with all the marketing names, you can't figure out the speed.  Ultra is slower than Extreme Plus?  How fast is Extreme?  Crazy.
    DAB over 4 years ago
    An interesting range of values for a simple IO device.
    Clearly you need to test and verify SD card performance for you application.
