Raspberry Pi
Raspberry Pi
Blog Seti@Home (boinc) on Raspbian for Raspberry Pi 2
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Date Created: 20 May 2015 8:43 PM Date Created
  • Views 842 views
  • boinc
  • pi
  • rpi2
  • seti@home
  • raspberry-pi
  • raspberry_pi_2
  • rpi
  • raspbian
  • feature_tutorial
e14 Contributor
e14 Contributor
20 May 2015
This is a much-needed update to the blog entry that I wrote in May 2015.  Thanks to subsequent comments by Daniel Carrion (off, busy on other things now), daywing, , suprimex , dirkbroer , and mchuntley.
In September 2016, the current Raspbian boinc-* packages will, indeed, get you a working boinc project on the Raspberry Pi 2 - just avoid installing the boinc-app-seti package from Jessie.  Yes, this blog entry is smaller because one year's progress has shortened the lengthy previous procedure required for the Raspberry Pi 2.
Recipe follows:
1. sudo apt install synaptic
     (great package manager if you have not already installed it)
2. Launch synaptic (enter the sudo password).
3. Synaptic: Search for "boinc"
4. Synaptic: Select boinc-manager
     (implies boinc-client and other dependencies)
     Note that boinc-app-seti (SETI@Home v7) in the Jessie repo is out of date and needs an update
     to v8.  This has already been reported.  I suggest adding SETI@Home when you first
     launch boinc-manager; this will automatically get you SETI@Home v8.
     Note that you can get many available boinc apps through the use of
     the boinc-manager (GUI) or boinc command line (`boinccmd`).
     I did not install the graphics because (1) more resources would be eaten up on RPi
     and (2) I'd rather do my own mathematical plotting.
5. Synaptic: Apply
6. Exit synaptic
7. On the menu bar, Applications > System Tools > BOINC Manager
     The initial red flashing notices is *NOT* an alarm but worth reading.
     In the future, this might indicate something worrying about.
8. Add project (SETI@Home) or any other project that appeals to you.  Sign-up or Login.
9. My personal preference: change View from Simple to Advanced.
Pictures at the beginning of this article:
  • Boinc Manager task tab showing 2 assigned Seti@Home assignments running at 100% of a CPU core each.
  • Boinc compute preferences.  If you notice pi-sluggishness in the future, you might want to un-check the "While computer is in use" box.  I do not believe that there exists yet any Raspberry Pi GPU support.  Maybe in the future.
  • Watching the boinc-client processes with `top`.
Any other Boinc users here at Element 14?
    Presently running one Rapberry Pi B+, two Raspberry Pi 2s and two Raspberry Pi 3s. My only problem is with QCN (Quake Catcher Network): they have their own Raspberry Pi client instead of doing their specific things in their application. As they have changed servers (and supporting universities) a bit you cannot download that client anymore and, to top it off: if you have no credits you can't post on their forum. New Raspberry Users are so denied access to that project. I had specially bought a Sense-hat for it....:(
    Other projects, running fine: Enigma, Wanless, Asteroids, Seti, Goofyx, WuProp.
