Raspberry Pi
Raspberry Pi
Blog Show messages on 16x2 LCD | Pi4J | JAVA | Raspberry Pi
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: oksbwn
  • Date Created: 23 Jan 2017 9:56 AM Date Created
  • Views 1923 views
  • tutorial
  • lcd on p
  • pi4j
  • pi
  • 16x2
  • raspberry pi
  • howto
oksbwn
oksbwn
23 Jan 2017
Showing messages on 16X2 LCD display by interfacing with Raspberry Pi using JAVA and Pi4J library.
Intro visual Source: http://pi4j.com
Links :
Java Application on Pi Playlist: http://bit.ly/2eB1O2K
Schematic : http://bit.ly/2kiVhvW
Pi4J GPIO Numbering : http://bit.ly/2ja20av
Download Pi4J Library : http://bit.ly/2j32blF
Code : http://bit.ly/2jPIoZs
Subscribe YouTube : https://goo.gl/FhfdL7
Guys Subscribe to my channel for latest contents into your inbox.
Support me to keep going.
___________________________________________
Website : http://www.weargenius.in
Twitter : https://twitter.com/geekybikash
YouTube : https://www.youtube.com/weargenius
Instagram : https://www.instagram.com/weargenius/
GIT : https://github.com/oksbwn
Facebook: http://www.facebook.com/geekybikash
    e14 Contributor over 9 years ago +1
    Great post! Its nice to see some Raspberry Pi projects using Java
    e14 Contributor over 9 years ago in reply to oksbwn
    Hi Bikash,
    first thank you for your answer: you're gentle.
    I rebooted the Pi but the error is still here. You can check the code here and i followed the video on the top.
    As you can see the program uses gpio.shutdown
    CODE:
    https://github.com/oksbwn/16X2-LCD-Raspberry-Pi_Pi4J/blob/master/main.java
    ERROR:
  • oksbwn
    oksbwn over 9 years ago in reply to e14 Contributor
    the Eclipse error is as usual and nothing to worry about it as you are compiling a program meant for Raspberry pi gpio on other system . so it's ok. now export the executable jar file and it should work. regarding the first one it looks like you are redeclairing the same gpio object. try to reboot the pi. and in the program you can use gpio.shutdown when you quit the application. you can achieve that by using shutdown hook.
    Hi, i followed the guide but there is this error when i execute the JAR file
    this is the OUTPUT of Eclipse
    What is the problem? i can't use the LCD with this error
    Great post! Its nice to see some Raspberry Pi projects using Java image
