Raspberry Pi
Raspberry Pi
Blog Simple din rail housing for Pi zero
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: hwhardsoft
  • Date Created: 6 Aug 2016 8:02 PM Date Created
  • Views 4484 views
  • Comments 24 comments
  • housings
  • enclosure
  • pizero
  • bread_board
hwhardsoft
hwhardsoft
6 Aug 2016
Hi,
I want to introduce a new enclosure project for the Pi Zero. It's a new din rail housing and protoboard with integrated voltage regulator.
Project home page
  • hwhardsoft
    hwhardsoft over 9 years ago +3
    that was exactely the idea behind this enclosure set. You can integrate other ciruits or boards together with a Pi_Zero (W) on a din rail.... Here another example with a Homematic IO-Module for the Homematic…
    balearicdynamics over 10 years ago in reply to fvan +2
    Frederick, I think that we should put the attention on the difference existing between a DIN rail enclosure and a simply standardised board with a couple of some more connectors. Price is the issue for…
  • hwhardsoft
    hwhardsoft over 10 years ago +2
    Hi, thx for you comments. Sorry, but I can't see a relationship between the price of the PiZero and especially this product. As Enrico explained, this is not a standard case - it's a problem solver, if…
  • hwhardsoft
    hwhardsoft over 8 years ago
    We've changed the board to a full THT design. Furthermore the voltage regulator is stronger now:
  • hwhardsoft
    now also available with transparent lid in the top shell
  • hwhardsoft
    that was exactely the idea behind this enclosure set. You can integrate other ciruits or boards together with a Pi_Zero (W) on a din rail.... Here another example with a Homematic IO-Module for the Homematic wireless automation system (very popular in Germany): The module represents 4 buttons with 2 rockers. IT's easy to control the "rockers" via the GPIOs of the Pi-Zero...
    balearicdynamics over 9 years ago
    Interesting the integration of the two boards. In a general view, IMHO, the interesting aspect is that this can be considered also a good prototyping platform. Is possible to provide the rail base supporting the PI-Zero with custom PCB ? I think that an option of this kind opens a lot of possibilities for derived specific products for industrial or home automation.
  • hwhardsoft
    we've tested the integration of Razberry module (enables Z-Wave wireless protocol) in our RasPiBox Zero din rail enclosure for Pi Zero.  It's a little bit more tricky but it works.
