Raspberry Pi
Raspberry Pi
Blog Simple din rail housing for Pi zero
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: hwhardsoft
  • Date Created: 6 Aug 2016 8:02 PM Date Created
  • Views 4484 views
  • Comments 24 comments
  • housings
  • enclosure
  • pizero
  • bread_board
hwhardsoft
hwhardsoft
6 Aug 2016
Hi,
I want to introduce a new enclosure project for the Pi Zero. It's a new din rail housing and protoboard with integrated voltage regulator.
Project home page
  • hwhardsoft
    hwhardsoft over 9 years ago +3
    that was exactely the idea behind this enclosure set. You can integrate other ciruits or boards together with a Pi_Zero (W) on a din rail.... Here another example with a Homematic IO-Module for the Homematic…
    balearicdynamics over 10 years ago in reply to fvan +2
    Frederick, I think that we should put the attention on the difference existing between a DIN rail enclosure and a simply standardised board with a couple of some more connectors. Price is the issue for…
  • hwhardsoft
    hwhardsoft over 10 years ago +2
    Hi, thx for you comments. Sorry, but I can't see a relationship between the price of the PiZero and especially this product. As Enrico explained, this is not a standard case - it's a problem solver, if…
    shabaz over 10 years ago in reply to uscdadnyc
    Hi Edward,
    It looks like their larger 'RaspPiBox Open Plus' (I don't get the naming scheme) uses a LM2576, but its unclear what they are using for the 'Zero box.
  • uscdadnyc
    uscdadnyc over 10 years ago in reply to hwhardsoft
    From what's posted, I cannot tell what physical dimension-ed Voltage Regulator is supported? To-220? OR To-03 package(s)? BTW I am not getting into the Debate (of this Cost of this product vs RaspPi Zero). I got my RaspPi Zero for 99cents (100 cents = (1) USD[US Dollar]) at a Promo Sale at a USA Micro Center Store.
    HW wrote (on 08AUG16)>>...
    The USB host will be accessabke from the outside. You can stick a WLAN USB stick in it to have access to the Pizero via SSH for example...
    USCDADNYC reply>>... great idea about WLAN USB Stick. I was thinking along those lines myself. Even possibly w/ a BT (Bluetooth) stick. I have a mini-USB USB Hub on order. will post results here. BTW1 one can get the SSH client "putty" at URL: bit.ly/win32putty. BTW2 this is a Windows-based "putty". ALSO what do you guys/gals use to make the GPIO "holes" available?
    I am thinking of (soldering) dual 20pin(s) male-pins onto the Solder Islands. Pins that are about 15mm (5/8") Tall. This way I can "slip" a RTC onto the GPIO pins easily. Any comments/Ideas?
    USCDADNYC (NY NY USA)
  • hwhardsoft
    hwhardsoft over 10 years ago in reply to fvan
    Ah ok. Yes you have to solder 4 wires to the usb pads. I'm thinking about a small mini usb plug (we fould a similar one for our old kickstarter campaign) in this case no soldering on the Pi is needed....
  • fvan
    fvan over 10 years ago in reply to hwhardsoft
    I must've misunderstood:
    The idea is to solder a cable between these pads and the corresponding testing point of the PiZero.
    So does your solution require soldering to the Pi or not?
  • hwhardsoft
    That's (exactly) what I said image
