Raspberry Pi
Raspberry Pi
Blog TOTAL NEWB NEED PLEASE HELP PROFESSIONALS WANTED
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Date Created: 10 Jul 2016 7:07 PM Date Created
  • Views 777 views
  • composite_video
  • composite_display
  • raspberry_pi_space
  • ras pi 3
  • ras pi
  • ras_pi3
  • raspberry pi 3
e14 Contributor
e14 Contributor
10 Jul 2016
Im trying to connect the NTSC/PAL TFT 3.5" Display to my Pi 3 buti broke off one of the connectors that i was gonna connect it to which i beleive is ground. Is there another spot i can connect it to (ground and 5v).
Also are these correct?
Also is there a diagram that shows all the purposes of all the back connectors? because all i find is the gpio pin out diagram but i dont need that.
I would appreciate it so much if someone could help me.
  • mayermakes
    mayermakes over 5 years ago
    Hi
    You can take ground from wherever is it present, for example the GPIO header.
    here is a list of the testpoints for the pi3B /B+
    PP1 VCC +5V (from micro USB receptacle)
    PP2 VCC +5V (from micro USB receptacle)
    PP3 GND
    PP4 GND
    PP5 GND
    PP6 GND
    PP7 5V after polyfuse
    PP8 3V3
    PP9 1V8
    PP10 Power LED
    PP11
    PP12
    PP13 Status ACT LED
    PP20 H5V (5V at HDMI connector)
    PP21 RUN (reset signal)
    PP22 Ethernet Activity LED
    PP23 Ethernet Link
    PP24 Composite Video
    PP25 L Audio
    PP26 R Audio
    PP27 USB VCC
    PP28
    PP35 VCC +5V
    PP36 USB D-
    PP39
    PP40
    PP41 USB D+
    PP42 USB D-
    PP43 USB D+
    PP44 USB D-
    PP45 USB D+
    PP46 USB D-
    PP47 USB D+
    PP48 GND
    PP49 GND
    PP50 GND
    PP51 GND
    PP52 Ethernet TX+ ?
    PP53 Ethernet 3v3 ?
    PP54 Ethernet RX+ ?
    PP55 Ethernet TX- ?
    PP56 Ethernet RX- ?
    PP57 Ethernet 3v3 ?
    PP58
    PP59
    PP60
    this thread has some more information and its also where I got the list: https://raspberrypi.stackexchange.com/questions/91901/what-are-the-functions-of-the-test-pads-on-the-pi-3b-3b
    With the broken connector there is a possibility that some traces may be shorted, so check them with a multimeter before repowering your Pi.
