Raspberry Pi
Raspberry Pi
Blog Video 1: Unboxing and Setting up the Peripherals - Supplemental Notes
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: pchan
  • Date Created: 19 Dec 2013 9:14 PM Date Created
  • Views 701 views
  • noobs
  • get_started
  • unbox
  • raspberry_pi
  • get_started_with_pi
  • configuration
  • unboxing
  • raspberry_pi_getting_started
pchan
pchan
19 Dec 2013
Follow along with Cabe and Jenny as they set up a Raspberry Pi
The Get Started with Pi video series makes it easy for anyone to follow along step-by-step to get started using their Pi.
The Starter Kit Includes:
  • Model B Raspberry Pi
  • Power Supply
  • 8GB NOOBS Software pre-programed SD Card
  • Protective ABS plastic case
You'll also need
  • A monitor (television or computer monitor will both work, provided they have the right inputs)
  • A Keyboard and Mouse
Connectors
  • See the list of suggested cables and connectors to choose what you need for your needs
Running Raspberry Pi Configuration
To get to the configuration tool after your initial install of the operating system, open LXTerminal and type: sudo raspi-config
Set the locale
The format is a two-letter abbreviation for language followed by an underscore “_” followed by a two-letter abbreviation for the country.  Always select the UTF-8 option, if one is available. Link to table of location/language values:  http://docs.moodle.org/dev/Table_of_locales
IMPORTANT NOTE:  The en_GB.UTF-I UTF-8 option will be pre-selected by default (the Pi comes from the UK after all).  Be sure to unselect this option (unless you’re in the UK) when you’re selecting your appropriate locale.
Time Zone Selection
Your Pi will not show the current time until you connect it to the internet, even after you select the time zone from the NOOBS configuration menu.  The Pi doesn’t have a real-time clock.  It will automatically get the time using the Network Time Protocol.
If you don't have an Internet connection then you can use the date command to set the date / time appropriately.
sudo date -s "Jul 5 08:10"
  • AnalogNotes
    AnalogNotes over 12 years ago
    OK, I feel like such an idiot dealing with this site.  Where is the actual video???  I clicked the picture, but that just pops up a dialog with the picture...
    EDIT: OK, I went back to the getting started page and found this link:  Get Started With Pi - Video 1: Unboxing and Setting up the Peripherals
    Why isn't it linked in this blog entry?  And why is the blog title a self-referential link?
