Raspberry Pi Forum Helicopter animation using a Raspberry Pi
  • Replies 32 replies
  • Subscribers 703 subscribers
  • Views 7375 views
  • pi animation
  • programming in python
colporteur
colporteur over 6 years ago
We are being encouraged by our leaders to practice social distancing and/or isolate ourselves where possible during this COVID19 crisis. To avoid going stir crazy while isolated in my home, I dug up an old project I have mulled over many times.
I would like to use a Pi to construct an helicopter animation. The best way to understand the goal of the project is let you take a look at the video. https://www.youtube.com/watch?v=Hl5--7g3jO0&t=112s
My first task is to build the light sequence. My light sequence is slightly different because it matches aviation specifications. There will be cabin lighting, landing lighting(front), position lighting (left/right/rear) and strobe lighting (top/bottom). All lights are either on or off with the strobes flashing when on. The lighting is being done with LEDs. Once I master the lights, I will integrate the audio and then tackle motor control. The Pi is responsible for running the whole show. I am looking to use python to accomplish the task. No, I am not interested in doing the project with an Arduino or in another programming language. Pi and python are my toolset. Hopefully I don't discover it is not possible.
What I am hoping for is some direction to developing the solution. I have no doubt this is programming 101 for many of you. I have much experience in programming. I have met and worked with people that have the skills to call themselves a programming. I am not a programmer.
The series of LED’s repeats the following sequence:
turn LED1 on solid
turn LED2 on flashing
turn LED3 on solid
turn LED4 on solid
turn LED4 off
turn LED3 off
turn LED2 off
turn LED1 off
cycle starts again.
My difficultly is creating the flashing LED within the sequence. I can turn all the LED's on and off. I can flash LED2 on its own. When I add flashing to the sequence LED2 flashes once and then the sequence continues with no more flashes. I require LED2 to flash continuous until it is turned off. I’m thinking I need to have a LED flashing routine (? another script) that is called in the parent script and continues to run (flash) until it is called to stop. I want to call it a fire and forget routine but that is my lack of programming terminology understanding.
I had this thought, write a code for a python module that flashes an led. Call the module in another python script giving it the pin number. The module should have a start and stop. Well that simple understanding of writing a module exceeds my knowledge. Since I'm not sure if what I am looking for is actually a solution, my research is proving difficult. If a module is what I need and you have a resource to assist in writing it, please let me know.
I'm not looking for someone to write the code but rather guide me to developing the code myself. Care to provide some insight into my helicopter animation COVID19 Isolation Project. There is no badge or points awarded, just a brain share. I look forward to your responses.
  • luislabmo
    luislabmo over 6 years ago in reply to colporteur
    Hi Sean,
    I think dougw 's idea is on spot and is the easiest to do without having to use timers, threads or a complex secs/micros/millis calculation. The key here is deciding the delay for each loop (a delay common enough for all actions to be a "factor" of such delay) and be creative on the math of how many loops you want and how you want to handle each action. e.g.:
    The "roug" example below will do the following
    • Blink ON or OFF a GREEN_LED, 1 second each state
    • Blink ON or OFF a RED_LED, 5 seconds each state
    • Engine -the following repeats every 100 seconds:
      • Seconds 0 to 19, the ENGINE is OFF
      • Seconds 20 to 34, the ENGINE will start accelerating
      • Seconds 35 to 80, the ENGINE will turn ON at full speed
      • Second 90 to 99, the ENGINE is OFF
    • The GREEN_LED and RED_LED sequence will act independently (doesn't matter what the engine sequence is doing)
    #Initialization
    cycleCounter = 0
    totalCycles = 100
    #RED_LED OFF
    #GREEN_LED OFF
    #ENGINE OFF
    while True:
         if cycleCounter % 2 == 0:
              #Turn GREEN_LED ON
         else:
              #Turn GREEN_LED OFF
         if (cycleCounter // 5) % 2 == 0:
              #Turn RED_LED ON
         else:
              #Turn RED_LED OFF
         if cycleCounter >= 20:
              #Turn ENGINE ON acceleration
         elif cycleCounter >= 35:
              #Turn ENGINE ON FULL SPEED
         elif cycleCounter >= 90:
              #Turn ENGINE OFF
         cycleCounter = (cycleCounter + 1) % totalCycles
         time.sleep(1)
    Luis
  • beacon_dave
    beacon_dave over 6 years ago in reply to colporteur
    Have you considered using the .blink() method in gpiozero ? It can be set to use a background thread:
    https://gpiozero.readthedocs.io/en/stable/api_output.html#gpiozero.LED.blinkhttps://gpiozero.readthedocs.io/en/stable/api_output.html#gpiozero.LED.blink
    Perhaps take a step back and look at this MagPi eBook:
    https://www.raspberrypi.org/magpi-issues/Essentials_GPIOZero_v1.pdf
  • colporteur
    colporteur over 6 years ago in reply to balearicdynamics
    Sorry M, you're going to have to dummy down your response for me to process. I'm the dummy:) I'm inputting at the rate of a paper tape reader punch and your outputting at the rate of SCSI 2 interface.
    I see some benefit to the concept of "Then a single function will set/reset the LEDs on/off as well as the motor, sound, and any other part that should be included in the animation." Understand the goal is to integrate the three components of animation, lights, sound and motions is important.  Unfortunately, I don't have the knowledge level to extrapolate what I need to do to accomplish this.
    I'm stuck on the simple concept of concurrency. Two tasks operating independently. On and off LED's and LED strobe on and LED strobe off. How do I do that?
  • colporteur
    colporteur over 6 years ago in reply to glennvanderveer
    Yes V Squared the additional commentary in the sequence is correct! Your additional commentary enhances to detail of what I am trying to accomplish.
    The pilots are in the helicopter running through a startup checklist. More than one thing happen at the same time. Lights will come on solid and some will flash. engines will start later generating sound and motor will engage rotors to turn.. The viewer on the outside just sees lights, hears engines and witnesses motion of the blades.
    My goal is to create this sequence using a Pi running python.
    dougw over 6 years ago in reply to colporteur
    Your problem could be handled with concurrent processes and it seems simple enough that you have a few things that might be independently occurring, but when you dive into implementing concurrency in a computer, it rapidly becomes a very complex topic. I doubt it could be distilled down to a paragraph of advice that would avoid a big learning curve.
    If you want to describe your problem a bit more theoretically than just the mechanics of loops, you could look into state machines. This problem can be described as a system that has different states at different times and the states follow a sequence. At any given time some, things are on and others are off - that defines the state of the system at that time. The loop counter we mentioned above is a way to implement a state machine. Every quarter second the system enters a new state. You just need to decide what needs to be on and what needs to be off in each quarter second.
  • glennvanderveer
    glennvanderveer over 6 years ago in reply to colporteur
    So this is what I whipped up quickly.  I have not tested or compiled this, but it works great in my head...image
    import threading
    import RPi.GPIO as GPIO
    def LED2_Blinker():
    if GPIO.input (LED2_PIN): #read teh led2 pin and if it is high, set it low
    GPIO.output (LED2_PIN, GPIO.LOW)
    else: #was not high, set it so...
    GPIO.output (LED2_PIN,GPIO.HIGH)
    LED1_PIN = XX #change XX to be proper pin number on PI
    LED2_PIN = XX #change XX to be proper pin number on PI
    LED3_PIN = XX #change XX to be proper pin number on PI
    LED4_PIN = XX #change XX to be proper pin number on PI
    GPIO.setup (LED1_PIN, GPIO.OUT)
    GPIO.setup (LED2_PIN, GPIO.OUT)
    GPIO.setup (LED3_PIN, GPIO.OUT)
    GPIO.setup (LED4_PIN, GPIO.OUT)
    #set all pins low to start....
    GPIO.output (LED1_PIN,GPIO.LOW)
    GPIO.output (LED2_PIN,GPIO.LOW)
    GPIO.output (LED3_PIN,GPIO.LOW)
    GPIO.output (LED4_PIN,GPIO.LOW)
    #setup the timer.  Number is for amount of time between timer activating...
    timer = threading.Timer(0.25,LED2_Blinker)
    # and now the looping sequence...
    while True:
    GPIO.output (LED1_PIN,GPIO.HIGH)
    time.sleep(3)
    timer.start() #starts the timer so that LED 2 will blink automagically
    GPIO.output (LED3_PIN,GPIO.HIGH)
    time.sleep(3)
    GPIO.output (LED4_PIN,GPIO.HIGH)
    time.sleep(3)
    #done startup sequence...
    time.sleep(3)
    time.sleep(3)
    timer.cancel() #stops the tiemr from firing until restarted...
    GPIO.output (LED2_PIN,GPIO.LOW) #ensure that LED2 is off (just in case)
    time.sleep(3)
    This should repeat forever, until you power it off...
    balearicdynamics over 6 years ago in reply to glennvanderveer
    I have just a doubt. The timer should be started inside the loop?
  • glennvanderveer
    glennvanderveer over 6 years ago in reply to balearicdynamics
    I don't think there is anything wrong with starting a timer in a loop because LED2 can't start blinking until after LED1 is has been on for 3 seconds.  The timer was setup before the while loop started, so when the timer expires/fires, it will run the LED2_Blinker routine and then exit and wait for another timeout.  This way returns the control back to the main while loop so it can run again...
  • colporteur
    I integrated your suggestion into my code. The sequence operates through the turning on of all LED's including the strobe. It starts the off sequence and fails at timer.cancel() line.
    My understanding about threads is there is no stop method. It suggests one way to resolve this is to be build a class which contains the start and stop methods.
    Your code is starting just not starting.
  • colporteur
    colporteur over 6 years ago in reply to luislabmo
    Thank you for chiming in.
    I've been struggling to get my head around dougw suggestion. Does my thinking align with this paraphrase of the method: all actions of LEDs, sound and motors are governed by the value of a counter. Each action required tests the value of the counter if true/false of test perform action (on/off, start/stop). The counter just cycles.
    How do I get granular control of the strobe light on & off time.  My current line of thinking this code
    def flashHZ (GPIO1):
      GPIO.output(GPIO1, GPIO.HIGH)  ## set HIGH (LED ON)
       time.sleep(.05)  ## wait
       GPIO.output(GPIO1, GPIO.LOW)  ## set LOW (LED OFF)
       time.sleep(.8)  ## wait
       return
    gives me the optimal flash.
    Break.Break...
    How did you display you code so cleanly in your post? The numbering and ability to scroll within the message is ideal. Can you share your insight?
