Raspberry Pi Forum Electronic serendipity
  • Subscribers 702 subscribers
  • Views 761 views
colporteur
colporteur over 6 years ago
I developed two PCB for different projects and stumbled on a third option.
One board is 3VDC-5VDC buffer/level shifter for Raspberry Pi. The other board is a multi-input, FET switch that provides 12VDC output. I discovered today if I replace the input screw connectors on the FET board with 2.54 header pins it mates perfectly with the outputs of the buffer/logic shifter board when I removed the boards output screw terminals.
YES, fist pump! This provides another output power option of 12VDC on the buffer/level shifter with minimal work. I explained my success to my spouse and all I got ambivalence.  I guess the satisfaction is a tech thing.
  • kmikemoo
    kmikemoo over 6 years ago
    colporteur  imageimageimage  At least you have us (the e14 community) to share the victory with.  imageimage
  • colporteur
    colporteur over 6 years ago in reply to kmikemoo
    Thanks M2. I kinda thought the discovery emotionally compared with grandchildren visiting but my spouse's disapproving eye suggests otherwise.
